ZDOG
Old 07-24-2012, 10:09 PM
Bighert3rd's Avatar
Bighert3rd Bighert3rd is offline
Vehicle: 2014 Ram 5.7L
Trim Level: Tradesman
Rep:60
Bighert3rd will become famous soon enough
Default Lowering/leveling questions
Looking to either level the rear or lower the entire truck, but have some questions.
1. Looking at the Ground Force rear leveling kit. Are these pretty easy to install? Is this something I can do in my garage or are special tools required? Anyone with this kit...if so any issues?
2. Also looking at the Ground Force lowering kit for 4 x 4. Anyone install this yet? If so any issues?
Thanks.
Old 07-25-2012, 02:26 PM
M.Scipione's Avatar
M.Scipione M.Scipione is offline
Vehicle: 2011 Ram 1500 Crew
Rep:41
M.Scipione is on a distinguished road
I have that kit but didn't install it myself.
Local suspension shop put it on and commented about having to make something to take out factory parts.
It sounded to me like there was some oddly shaped tamper resistant 'security' bolt back there.
Old 07-25-2012, 08:26 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
I haven't installed the GF leveling springs, but I did cut my springs in the rear. Was super easy, and was completed in about 45 minutes.
If a suspension shop had issues installing rear springs, I would have probably went else where as it can't get too much easier.
- Lift the rear truck by the pumpkin using a floor jack. I lifted as high as I could go.
- Place jack stands on the frame just in front of the rear tires using one of the higher settings
- Unbolt the lower shock mounts
- Unbolt the sway bar from the end links
- Slowly lower the truck down onto the jack stands, continue lowering the pumpkin till the tires are about an inch or two above the ground.
- I marked the bottom coil and bottom perch with 1 yellow line on the left, and the right side with 2 yellow lines. That way when I reinstall I know right from left and exactly how the spring was inside the perch.
- Lift the spring up a bit and slide the bottom out of the perch.
- I cut mine, so I cut 1.5 coils off on each side and that lowered my crew cab 2"
- Install the springs and line up the yellow marks on each side.
- jack the pumpkin back up
- Install the sway bar end links
- Install the lower shock mounts.
- Remove jack stands from under the truck,
- Lower jack
- Open beer
- Drink beer
- Stand back and admire the truck
Old 07-26-2012, 11:20 AM
fullmonte60's Avatar
fullmonte60 fullmonte60 is offline
Vehicle: 2011 Ram 1500 Express
Rep:19
fullmonte60 is on a distinguished road
nice job. looks great. if you get tired of it you just need to pop in 2 springs.
2011 Ram 1500 Express, Hemi, Black, Jet PCM, Airaid, Magnaflow 10778 & 12198, BT catch can, Bed Armour, Lund Genesis Tri-Fold, Debadged.
Old 07-28-2012, 11:13 AM
Mopar Big Horn's Avatar
Mopar Big Horn Mopar Big Horn is offline
Vehicle: 2011 RAM 1500 crew cab 2wd
Color: PR4 Flame Red
Rep:148
Mopar Big Horn will become famous soon enoughMopar Big Horn will become famous soon enough
looks good with the back lower. also like the front, did you plasti dip the grille inserts? did you have the grille painted to match or come like that?
Check my mod list.
Old 07-28-2012, 11:51 AM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Before I lowered my truck it was leveled with this kit.
http://www.sdtrucksprings.com/tuftru...-springs-09-12
Old 08-06-2012, 10:27 PM
mk3barti mk3barti is offline
Vehicle: 2011 Sport
Color: Black Pearlcoat
mk3barti is on a distinguished road
I have had the GF on my truck for a couple of months. Install is pretty easy although the upper shock mount bolts are tucked away and takes a bit of creativity to get a socket on them. The instructions that come with the kit are very detailed and helpful. I would say it is a couple of hours start to finish. Great kit that I would highly recommend.
Old 08-13-2012, 07:13 PM
immokalee98's Avatar
immokalee98 immokalee98 is offline
Vehicle: 2011 Dodge Ram
Color: Black on Black
Rep:16
immokalee98 is on a distinguished road
How is the ride after it is lowered?
Old 08-14-2012, 04:41 PM
Jayincali's Avatar
Rep:95
I PD the Rams head, then ordered the grille surround, the inserts are the honeycomb inserts that came with the grille. I think I paid about $230 shipped for the entire unit.
