Old 08-09-2012, 01:57 PM
DS12Express DS12Express is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: ST Express
DS12Express is on a distinguished road
Question Improving ride quality...
I have a 2012 Ram 1500 Express regular cab with the 6'3" bed with 6k on the odo. I've replaced a Hellwig front sway bar in place of the stock one and the McGaughey's rear lowering springs/shakles on the rear which brought the rear down only about 1".
I would like the truck a bit lower for easier in/out for me and my wife and I would like to improve the ride quality. The short wheel base rides a bit rough! According to my VIN, the dealership says I have a "performance suspension" and they show no options available from Dodge.
So, I've checked out Ride Tech, Air Ride Technologies and Belltech for air ride systems. Belltech doesn't make one for my application. Is an air ride system my only option, or:
1. check tire pressure and if too high, lower it a bit and soften the ride?;
2. have "softer" shocks installed on all 4 corners?; or
3. ???
Any and all help is appreciated, thanks!
Old 08-09-2012, 03:35 PM
TurboCup87 TurboCup87 is offline
Vehicle: 2012 1500 Sport Crew 4x4
Color: Blue
Rep:28
TurboCup87 is on a distinguished road
One way to improve the ride is to drive the other brands! You'll notice how good our trucks are right away.
Old 08-09-2012, 05:42 PM
jpeltier's Avatar
jpeltier jpeltier is offline
Vehicle: 2012 dodge ram express 1500
Trim Level: Quad Cab Express
jpeltier is on a distinguished road
I have the same truck and i am wondering about the same ride quality question your having. I had KYB shocks on my 07 ram and it helped out alot. I am thinking of going the same way with my 2012.
Old 08-09-2012, 06:55 PM
X231 X231 is offline
Rep:16
X231 is on a distinguished road
As for ease in and out you can't beat AMP power boards. I love mine.
Old 08-09-2012, 08:33 PM
RAT ATK RAT ATK is offline
Vehicle: 2011 Ram
Trim Level: QC Outdoorsman 4x4
Color: Blue Pearl/Mineral Grey
RAT ATK is on a distinguished road
Easiest way to improve ride is go down to 17" wheels.
Old 09-06-2013, 01:34 PM
superdlb's Avatar
superdlb superdlb is offline
Vehicle: 2012 Big Horn 1500 4WD
superdlb is on a distinguished road
I totally agree!
Old 09-06-2013, 07:39 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
A lot of guys like the Bilstein struts for improved dampening.
Simon
Old 09-06-2013, 08:35 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
I put on GroundForce 2" rear lowering springs with their shorter shocks. Helped alittle getting in and out. You can go with 17" or 18" wheels and a tire that has a taller sidewall for better ride, but go with 31" diameter vs stock 33" diameter and you lower truck 1" with more sidewall flex. Is the sway bar you put on smaller diameter? Smaller diameter swaybar=better ride, but more body roll in hard turns. Monroe Sensatrac shocks will give better ride but they are made for stock ride height.
If you really want a smoother ride you will have to contact a suspension company that knows what the stock springs are rated. Lets say the fronts are 700lb spring rate with a compressed height of 8.5", you could then get a spring with a compressed height of 7.5" (1" lower) at a spring rate of 450lbs. You would have a 1" lower ride with a much softer ride because of softer springs.
I was lucky, I worked at NAPA and had a catalog that showed compressed height's spring rates on all the different kinds of coil springs. They are not all alike. I had a 87 Monte Carlo SS, I wanted a stiffer front end because of bigger tires. Went from stock SS springs (450lb rating?) to a spring that had 725'ish lb rating, but with a compressed height that was 1" lower. Still had to cut 1/2 coil to get ride height exactly where I wanted it, but was perfect stance when I was done. Takes time, but worth it in the end.
Maybe its as simple as putting 6 cylinder front/rear springs/shocks in place of the "Express" performance ones.
Bottom line...its a truck with a "performance" suspension, its not going to ride like a four door sedan. It can, but you have some work cut out for you. Sorry for long rant, it takes me a lot of words to get my meaning out the way I see it in my head.........
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it harder if your stupid." How would you know?
Old 09-06-2013, 08:36 PM
Asur Asur is offline
Vehicle: .
Rep:4371
go bilsteins on all 4 corners, and 17 inch wheels, JMO
Old 09-06-2013, 11:31 PM
oldhp's Avatar
Color: WHITE
Rep:902
Hers a place that makes custom springs. They even a RAM on their face page.
Coil Spring Specialties
