Old 08-10-2012, 05:01 PM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Default Need assistance with rear view camera install
Right now I am stumped, I believe I have everything wired up as it is supposed to be.
I have a new rear view camera, that is wired to the headunit using new RCA cables.
The cameras power is tapped into the reverse light, the camera is grounded.
The Headunit switches to the camera when it senses the truck in reverse, which is done by hooking the reverse wire on the headunit to the reverse light.
Right now when I switch into reverse, the head unit senses it and shows the rear view camera screen, but no picture from the rear of the truck is showing up.
Any ideas, I've done this before and I am replacing a faulty back up camera with a brand new one, including running new wires and all. I've already made sure all my connections are solid.
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 08-10-2012, 05:30 PM
MoparMike10's Avatar
MoparMike10 MoparMike10 is offline
Trim Level: Lone Star w/ 26L pkg
Color: Brilliant White Clearcoat
Rep:65
MoparMike10 will become famous soon enough
What head unit are you using? For my Pioneer, there is a menu setting for Camera Polarity which had to be set to Positive, which was the wire that I tapped into at the tail light to power the camera. Before doing this it was a blank screen just like you have.
Edit. Saw the head unit in your sig, this should be your problem if everything is wired properly as you said.
Audio - Pioneer AVH-P4400BH - PPI Phantom 900.4 and 1000.1 - Boston Pro 60s - Hybrid Audio Legatia L3s - 2x Image Dynamic IDQ10s
Mods - GroundForce 2/3 lowering kit - 24" Color-matched Wheels - K&N Intake - Katzkin Leather Interior
Old 08-10-2012, 11:12 PM
bigpercentcountry's Avatar
bigpercentcountry bigpercentcountry is offline
Vehicle: 2008 Dodge ram
Trim Level: SLT Big Horn
bigpercentcountry is on a distinguished road
I initially plugged my camera into the wrong plug on the back of the head unit (Pioneer 4300), experienced the same problems you are. You may want to double check just to be sure. I had to dig up my stereo manual to clear it up...
Old 08-14-2012, 07:32 PM
sullivan's Avatar
Rep:202
It ended up being a faulty power cord, replaced it and now it works awesome!
Mounting location, I used scrap aluminum. Won't rust either which is a plus. I plan to paint it black:
Adjusted
With the red line on the screen with the bottom of my garage door, this is how close I made it to my garage, I'd say this is a comfortable safe spot in parking lots.
