Old 08-11-2012, 04:04 PM
babears babears is offline
Vehicle: 1996 Dodge ram 1500
Color: red
babears is on a distinguished road
replaced IAC no change in the poor performance it did seem to idle better could just be wishfull thinking
Old 08-13-2012, 03:05 PM
namretsud's Avatar
namretsud namretsud is offline
Vehicle: 2007 1500 Mega Cab 4X4 3.73
Color: Inferno Red
Rep:185
namretsud has a spectacular aura aboutnamretsud has a spectacular aura about
Either pull out your precat o2 sensor or drop 1 side of your exhaust and try to see if you rpm level gets to more than 3000. If so you have a plugged cat. My cat did this when it went and when I changed it out I got full rpm back.
Old 08-13-2012, 03:40 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:85
Backfiring usually means vacuum leak. Biggest offender is intake plenum gasket. It should look oily inside but since you've been pouring gas in it, that's maybe not so obvious. Stop doing that, by the way. It's a dry intake. You're not supposed to pour gas innit!
Old 08-13-2012, 04:01 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
I agree with Gen1, to an extent. Mine had an issue with backfiring in the intake that's why I originally asked where it was backfiring from. I wound up changing the injectors because mine wasn't getting enough fuel (and therefore too much air) which is the opposite of a vacuum leak...I think. It ran decent when cold but as it started to warm up it went downhill fast.
Knowing where it's backfiring from is a further step in the right direction.
Old 08-13-2012, 07:06 PM
Rep:85
Either way, you get a run lean condition causing backfiring.
Old 08-13-2012, 07:08 PM
Vehicle: 95
Rep:1776
Yeah I agree that it's the same end result. I apologize if it sounded more argumentative than agreeing.
runs rough backfiring
