Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 08-11-2012, 03:32 AM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Default 75W140 gear oil????
Why is it that my owners manual says to use 75W140 rear gear lube on my 2012 2wd Express, but if it was 4wd or 2500 or 3500 to use 75W90 gear lube? Doesn't make sense to me. Any thoughts here?
Thanks
oldhp
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it harder if your stupid." How would you know?
Old 08-11-2012, 04:03 PM
sport2012ak sport2012ak is offline
Vehicle: 2012 dodge ram
Trim Level: sport
Color: true blue
sport2012ak is on a distinguished road
thats because with 4wd model they expect the truck to be towing thats why the use the different gear oil. you can you use the 75/140 if you are goin to be towing with. but make sure that you use a full syn. gear oil and get some mopar limited slip fuild dont use the stuff that you can get at your local parts store.
Old 08-11-2012, 05:06 PM
oldhp's Avatar
Color: WHITE
Rep:902
But wouldn't you want a heavier rear gear oil if towing? 4WD you would think will have the 75W140 in the rear end, while the 2WD would have the lighter 75W90.
Seems backward to me.
oldhp
