suggestions on drop kits??? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-13-2012, 12:34 AM
RAW1500's Avatar
RAW1500 RAW1500 is offline
Vehicle: 2004 dodge ram
RAW1500 is on a distinguished road
Default suggestions on drop kits???
How is everyone doing?.. Just woundering on what you guys are doing for drop kits for a 04 single cab. I have been looking at the djm 3-5 drop and the 4-6 from mcgaughy. For the price these arent to bad. Any feed back or suggestions would be greatly appreicated
DD- 04 single cab hemi
Project Unnaturally Aspirated-94 Nissan sunny (se-r)
Old 08-13-2012, 11:15 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:627
Been running my 4/6 McG' for about 4 years with no real concerns. Just FYI to inspect your factory perches and add welds to strengthen if need be. Also if you run 17's that it may or may not clear the drop spindle nuts so if you have clearance issues then shave the lower spindle nut until it clears. Again it is only if you are running 17's.
You most likely will need to swap our your factory front bump stops since those cans will be touching if not laying on the LCA. The McG' kit comes with rear bump stops so your set there.
Stock Height
4/6
Old 08-15-2012, 02:47 PM
RAW1500's Avatar
went with the mcgaughy 4-6 drop. Also looking into a ES bushing kit. But one more question?.. would putting the djm LCA and keeping my stock springs work? Only asking because i need to do my ball joints and factory lca's cost a whole lot more.
