Old 08-13-2012, 12:49 AM
avocat40 avocat40 is offline
Vehicle: 1994 dodge ram 1500
Color: forest green
avocat40 is on a distinguished road
Default dash cover 94 ram how do i remove top pad
Hi i need to get behind the dash to have accesto antenna lead to connect to radio i took out the screws on top near windsheild the 2 on ends and the ones behind bezel but the cover will not budge anything else to undo or i have to take the whole dash off to get back there to locate the lead near heater box , i saw adds for dash covers that seemed esay to install is 1994 models different? help im tiered of listening to radio static
Old 08-13-2012, 03:28 PM
Color: forest green
anybody? i can move the cover on the drivers side but it seems as on pass side above glove compartemet it wont budhe i don t want to breal the cover as its in great shape is there some screws or clips somewhere on pass side ? help
Old 08-13-2012, 04:30 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Uh yeah but the easiest way to remove it is to pull the entire dash...and that's about 4/5 hrs worth of work. Look into a Dash Cap for a good solution there's a couple reviews and a video here.
But then again...if it's in great shape...can I ask why you're removing it?
Old 08-14-2012, 12:53 AM
Color: forest green
like i sai the antena wire is unpluged somewhere under there as i pulled the wire from the firewall and its not conected yo the radio its a extention wire from the radio so i have no recption i want to reconnect the 2 wires but cant pull the one from ubder the dash its solid so i have to get back there
Old 08-14-2012, 08:52 AM
Vehicle: 95
Rep:1776
The whole dash has to come out to get the top off.
There are about 26 8 mm screws scattered around under there and the antenna wire has at least 2 tabs with screws holding it in place.
To be quite honest I'd run a new antenna wire or find someone with a camera to fish out the original.
Old 08-14-2012, 11:19 PM
Color: forest green
well looks like i will go out and buy a extenstion wire and pass it by the doorgromet for speaker wire as i dont want to break the dash thanks
