Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-14-2012, 02:34 PM
countryboy85's Avatar
countryboy85 countryboy85 is offline
Vehicle: 2007 Dodge Ram 1500 4.7L
Trim Level: SLT Big Horn
Rep:16
countryboy85 is on a distinguished road
Question Continued Heating/ A/C problems!!!!
OK. In a previous post, I was having issues with my heating and a/c. I could switch the blend door between the two by had, but not by the temp control dial on dash.
I was tinkering around last night and opened up the blend door actuator motor to find that the dial on the dash was not operating the actuator. I tested the actuator with a couple wires and a 9V battery and it still works.
So now I know that the problem is either the temp control switch or the wiring leading to the actuator. Does anyone know of how I may be able to test the connection to see if its a short or a bad switch? If it is the switch and not the wiring, can I replace just the switch, or am I stuck replacing the entire heater/air control?
Old 08-16-2012, 10:29 AM
linsys linsys is offline
Vehicle: 2000 Dodge Ram 1500
linsys is on a distinguished road
How did you switch the blend door by hand? I am all of a sudden having problems with my heater and its been working perfectly. I remember I had a Ford Explorer and the blend door went out but I could tell because of the loud clicking noise... I'd like to see if I can manually switch the blend door to see if the heat starts.
Old 08-16-2012, 03:27 PM
Rep:16
You have to find the blend door actuator motor which is under the dash on the passanger side. There are two screws that fasten the motor to the blend door and the rear screw is a PAIN to get to. Once you pull the actuator motor down, you can get to the rod that swings the blend door between heat and A/C. Check the little plastic piece that connects the blend door motor and the blend door. This generation of Ram has a problem with that piece cracking or breaking. If that's what's wrong, you can get a metal replacement piece from Heater Treater for about $30. They also have a video on their website that will show how to get to the blend door motor.
Old 08-16-2012, 08:44 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Have you tried the thermal relay or checked it? If it's bad the door won't operate even if it is good.
Old 08-21-2012, 04:34 PM
Rep:16
I tried to look up the thermal relay for the '99, and I don't think it has one. Am I correct in thinking the relay is located in the fuse pannel? I'm having one of those moments lol.
Old 08-22-2012, 10:01 PM
Vehicle: 95
Rep:1776
Nope, it's under the passenger's side of the dash behind the fan motor.
The black part is what you'll see. and it's held in with 2-7 or 8 mm screws.
Depends on where you are...some call it a blower motor resistor.
If you sit in the Pass seat and lift your left foot, you'll touch the plug and see where it's at.
Old 08-24-2012, 11:56 PM
ModelTFan01's Avatar
ModelTFan01 ModelTFan01 is offline
Vehicle: None
Rep:49
ModelTFan01 is on a distinguished road
I'm new here and since I'm 13, you really shouldn't take any advice from me (since I'm not a professional) I am knowledgeable about electronics and even more knowledgeable about HVAC (heating and cooling) equipment.
I, however don't know much about automobile HVAC systems, although it should be the same principal.
My advice: Look for the relay (like Warlock III said) and that may be your problem! The relay is usually a little black box with four wires hooked to it (the wires may depend from it being a SPST, SPDT, DPST, or DPDT type relay.)
I can probably help you find the relay if I had an electrical schematic. I'll try Google and other things since it's the weekend.
I'm glad to help in any way, shape, or form. Like I said, I don't know much about car's nor am a professional. I just happen to know a lot about HVAC equipment.
