sagging parking brake - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 08-14-2012, 02:05 PM
simonmw75 simonmw75 is offline
Vehicle: 2009 Dodge Ram
Color: Graphite
Rep:72
simonmw75 will become famous soon enough
Default sagging parking brake
Hello all,
Hopefully someone has seen this before. I have an 09 Ram with a sagging parking brake cable. When the brake is applied, it is tight. Once i disengage it, the cable sags along the length of the truck. Everything seems to work properly, meaning that the parking brake is holding the truck in place, and i don't smell or feel anything that would indicate that one side or the other is sticking. However, i could be wrong.
Any ideas?
Thanks
Old 09-04-2012, 08:56 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"New Cummins here we go"
Trim Level: Longhorn Rambox
Rep:1648
Let us know how you make out and please keep us updated.....
Old 09-27-2012, 03:55 PM
3500RammerJammer 3500RammerJammer is offline
Vehicle: 1999 Dodge Ram 3500 Cummins
Trim Level: My tranny is an auto
Color: red
Engine: 1999-2000 359ci (5.9L) Cummins ISB 24-Valve Diesel I6 235hp 460lb/ft (manual)
3500RammerJammer is on a distinguished road
Jack up the truck and use jack stands (safety first), check the parking brake parts under the truck for bent/faulty hard parts. Replace anything bent or bad. Adjust the cable underneath the truck until the slack is out, not tight enough to engage, just remove the slack. Engage the parking brake, check how it works. Hopefully it's just slack, let us know.
Old 09-27-2012, 04:34 PM
Rep:2968
I believe that you just have a cable loop or bracket that is damaged or broken
it will be close to the frame
I believe the cable runs along the drivers side frame rail & at one point meets up with another bracket & sort of forms a Y, at that point the one cable becomes two cables, both run to each rear wheels backing plate.
If when you apply the emergency brake, the brakes are correctly applied & the vehicle does not move or is hard to move even in a forward gear & they release when you pull the brake release lever, they are adjusted properly
Old 01-14-2013, 07:54 PM
Color: Graphite
Rep:72
Sorry guys. Just saw the replies. Haven't visited this in while. I'm hoping it's just a missing or broken support. I haven't noticed any change in how the brake holds the truck. I put it in neutral on a hill, and it held.
Old 03-29-2013, 03:46 PM
BigHorn09 BigHorn09 is offline
Vehicle: 2014 Ram
Color: Black Clear Coat
BigHorn09 is on a distinguished road
Mine sags down the same way and the park brake doesn't seem to hold very well. Any suggestions on adjusting it or is there a bracket missing?
Old 08-03-2014, 02:45 PM
chrisplm chrisplm is offline
Vehicle: 2011
Trim Level: sport crew
Color: brilliant black
chrisplm is on a distinguished road
I've had the same issue for years (2011 w/30k miles)
I'm finally taking the time to look into it.. the cables all move freely. But the Levers that go into the back of the brake assembly are sticking. removed, replaced and lubricated parking brake shoes and hardware kit. still sticking.. it appears to be where the lever enters the brake assembly is just all rusty. Crappy part is that in order to really get to it, you have to remove the rear axle.. .not something I really feel like doing!
Old 08-13-2014, 10:40 PM
Vehicle: 2011
Default Problem Solved... not what you think it is...
Ok. so I finally dug into this over the weekend..
It was not the cables, it was not the pedal mechanism, it was not the springs or shoes... it was a little "Lever" that separates the shoes when the cable is pulled. The lever is supposed to pivot inside itself. but mine were both rusted in position. They are a pain to get out without removing the axles, but it can be done. They need to be cleaned and greased.
You may be able to get yours freed up by spraying some wd40/ pb blaster in the boot that the lever goes through the back side of the mouting plate, and moving it back and forth.. I was not so lucky, I had to disassemble the brakes, remove the part, and clean it up on the bench.
here is a picture of the Trouble making part.
Old 10-20-2014, 02:01 PM
Color: Graphite
Rep:72
Thanks for the input. I'll have to make sure those things are moving when i apply the brake.
Old 07-27-2015, 08:51 PM
elyakins elyakins is offline
Trim Level: laramie
Color: Black/Silver
elyakins is on a distinguished road
I am in the middle of exactly where you have posted the picture. That part does not move at all. Hope i can free it up so I do not have to remove it completely. By they way, I use my e brake 1x per year. 111,000 miles on it and the e brake pads are gone...Wonder if this is why i have such bad gas mileage....
