Old 08-14-2012, 02:37 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
Default Dry Shot with Stock Injectors
Looking at dry shot kits, wondering if I get a 70-100 dry shot will my stock injectors be able to keep up safely? Anyone running a dry shot?
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 08-14-2012, 03:42 PM
SilentService SilentService is offline
Vehicle: 2012 Dodge Ram
Trim Level: 1500 Crewcab
Rep:49
SilentService is on a distinguished road
I remember when I had my 5.7 charger I was able to run a 125 wet kit no problem. Might post this over in the Nitrous section and see if anyone can get to it quicker.
click me
Im curious to know as well
Old 08-14-2012, 09:58 PM
FrostKing's Avatar
FrostKing FrostKing is offline
Vehicle: 2003 Dodge Ram
Color: Graphite
Rep:21
FrostKing is on a distinguished road
Your stock injectors won't add any fuel at all and your motor will go boom. Don't use a dry kit.
2014 White Crew Sport 4x4 8-speed 3.92 gear
Sold: 2003 RCSB 2WD
6.4L Hemi - Turbocharged, Alcohol, Nitrous
Old 08-14-2012, 10:06 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
http://www.ramforumz.com/showthread.php?t=112530
Old 08-14-2012, 11:28 PM
I push the skinny pedal
Rep:3277
A dry shot will not make you a happy person at those levels. Without a MAF you're pushing your luck at even a 50 shot unless you have a wideband installed and know if you're starting to run lean.
A wet kit is your safety and most reliable bet and you can easily run a 75 shot with 1 stage colder plugs on the stock tune. You don't neccessarily need the colder plugs, but without being able to tune you should try to protect yourself as much as possible. I personally run a wet shot on mine regularly with capabilities of a 150 shot, but it's a tuned n/a high compression stock bottom-end engine runnig 2 stages colder.
Kurtis
Old 08-15-2012, 09:07 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
jeez you just keep wanting more speed!!! where are the videos of the new cam?!?!?
-Pat-
Old 08-15-2012, 11:22 AM
Color: RED<----
Rep:15
I wasn't aware we didn't have a MAF so yeah wet will be the best. Not something I'm gonna do right now but was curious. And I'm gonna put some videos together soon and post them. Get good idle video with some good outside exhaust sound it's so sick lol
Old 08-15-2012, 11:30 AM
BlackHemI's Avatar
Rep:296
yea i bet! way to keep us waiting!
-Pat-
