water leaking...cracked block? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-15-2012, 12:51 PM
theskinsfan74 theskinsfan74 is offline
Vehicle: 1996 Dodge Ram
Trim Level: Regency package
theskinsfan74 is on a distinguished road
Angry water leaking...cracked block?
Had water leaking from what looked like to me was the water pump. So i replace the water pump, thermostat,put everything back together and the the thing is still leaking from the same spot, looks like its coming from behind or around the WP somewhere. Help please!!
Old 08-15-2012, 02:55 PM
After further inspection, i believe its the timing chain cover gasket. I know i should have went ahead and replaced it while i had the water pump off, but oh well. Not wanting to tear into it again, i went to Advanced and bought a bottle of "Bar's Head Gasket Fix". 30 seconds after adding it to the radiator, i watched the leak come to a complete stop.
Old 08-16-2012, 01:43 AM
JwhiteH JwhiteH is offline
Vehicle: 2001 Ram 1500 Sport
Rep:15
JwhiteH is on a distinguished road
Possibly the timing chain cover. Have you checked the coolant temp sensor?
Old 08-23-2012, 12:24 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
The timing chain gasket is prone to leak. However, the new gasket that Mopar has out now is much better.
Old 09-01-2012, 11:32 PM
Rep:15
Mine is leaking too... I don't want to do it but I am soon.
Old 09-05-2012, 03:15 AM
Rep:15
So I found the source of my leak. After replacing the thermostat housing and water pump, I still had the leak. Turns out it was the bypass hose going from the water pump to the block underneath the alt/ac bracket. It's $5 and not too difficult of a job. I would check there. The way I found out it was that was when I pulled my t-stat housing I decided to peek down there and sure enough, swollen and cracked hose.
Old 09-19-2012, 06:40 PM
toprjf739 toprjf739 is offline
Vehicle: 1997 Dodge Ram 1500
toprjf739 is on a distinguished road
I had the same issue, replaced bypass hose, pump. timing chain gasket. still had leak. Some of the bolts for the water pump go through the timing chain cover into the block, You may need to put sealant on the bolts that go through the timing chain cover into the block. seepage from the block will travel through the timing chain cover and leak at the bolts on the water pump. I put some water pump gasket sealant on the threads and leak was gone. Since I was going to replace the timing chain cover gasket I decided to check the timing chain. I replaced that too. The new chain made a big difference in how my engine was running. 178K on engine
