Old 08-15-2012, 03:12 PM
faxxy's Avatar
faxxy faxxy is offline
Vehicle: 2010 Ram 1500
Color: Not Black
faxxy is on a distinguished road
Default Any way to start it with just the key?
I just bought my 2010 Ram 1500 last week. I was poking around on it and realized that the regular (metal) key won't fit in the ignition.
Is there a place to put the key to start the truck when the battery goes dead in the fob?
Old 08-15-2012, 06:52 PM
EDTMAN EDTMAN is offline
Vehicle: 2012 Ram 2500
EDTMAN is on a distinguished road
Good question...So much for the spare key in your wallet. I am not a fan of this setup.
Old 08-15-2012, 07:10 PM
faxxy's Avatar
Color: Not Black
There's a spare key built inside the fob. But so far, all I can tell it does is open the door. Someone told me it was so you could carry a spare battery in the truck and if your fob dies you can at least get into the truck and get the spare battery.
Old 08-15-2012, 08:01 PM
Holleywud's Avatar
Holleywud Holleywud is offline
Color: Austin Tan Pearl
Holleywud is on a distinguished road
I'm pretty sure the fob will start the truck even if the fob battery is dead.
Old 08-15-2012, 11:39 PM
sottis sottis is offline
Vehicle: 2010 Dodge Ram Laramie 4x4
sottis is on a distinguished road
holleywud is right.
Old 08-16-2012, 08:54 AM
dkerr24 dkerr24 is offline
Vehicle: 2011 Dodge Ram
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
Tested and confirmed. The FOB will start the vehicle, even if the battery has been removed from the FOB.
To give myself some spare keys, I bought 2 chipped metal keys from a online reseller, took the keys to my Dodge dealer, who cut the keys to fit my locks and they programmed the key to start my truck.
Cost:
$20 for each key
$20 to cut/program them
The key will unlock the door/tailgate and will start and run the truck. The key has the same notch that the FOB has that allows it to fit in the ignition.
Darin
Old 08-16-2012, 07:39 PM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
Just had a funny experience. The FOB was beginning to play up, stopped at the store took the FOB apart to check battery size took the key out to lock the truck left the dismantled fob in the truck. got the new battery came back and unlocked the door with key the alarm went off and I could't stop it until I put the Fob back together.
Old 08-17-2012, 05:50 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
Darin
Do you have pics of this weird looking key? I just can't seem to visualize a metal key that is shaped like the fob that will start the truck
Exco
Bill
Old 08-17-2012, 06:37 AM
jacksonsnorth's Avatar
jacksonsnorth jacksonsnorth is offline
Vehicle: 2012 Dodge Ram 1500 QC 4wd
Rep:69
jacksonsnorth will become famous soon enough
Exco
I was trying to get the same mental picture...
The Rammin' Fool from Maine
Stubby Antenna, Bed Net, Toyo Open Country tires, Bilstein 5100 Ride Height adjustable set at 2.1 ..Tow Hooks in house ready for install. More to come!
Old 08-17-2012, 09:59 AM
Ferris18's Avatar
Ferris18 Ferris18 is offline
Trim Level: Limited
Ferris18 is on a distinguished road
Default Regular Key in New Dodge Rams
I believe the key will only work the door locks and the tailgate. I have been told that if you try to use the key you won't get far and it will shut your computer down and it is off to the dealer to get it re-set.
