Old 08-17-2012, 03:27 PM
gregster's Avatar
gregster gregster is offline
Vehicle: 2014 Ram Crew Cab
Rep:81
gregster will become famous soon enough
The key "in" the fob can be pulled straight out from the end of the fob (where the loop is for a keychain). Just slide the release tab over to the left and pull it out.
Ambitious, but rubbish!
Old 08-17-2012, 07:25 PM
faxxy's Avatar
faxxy faxxy is offline
Vehicle: 2010 Ram 1500
Color: Not Black
faxxy is on a distinguished road
They look like this...
Old 08-17-2012, 11:17 PM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
I will go back to my experience and explain again. I have extra key which can be removed from the Fob I also have the same key which is not attached to the Fob or built into the Fob both these keys work to unlock the doors and tail gate and in my case also the ram boxes.The fob unlocks the doors and starts the truck as well as other electric functions it was designed for, it does not open the tail gate or the ram boxes.The only way i can start the truck is with the Fob.The other day I took the Fob apart to replace the battery but left the dismantled Fob in the truck and locked the truck with the key came back and unlocked with the key and the alarm went of and the only way to turn it of was put the Fob back together with the battery installed.My truck is a 2009 Laramie I don't know if the key arrangement has changed on later models or if some of the other models are not equipped with an alarm system, I would be surprised if the Fob started the truck without a functioning battery but I could be corrected on that.
Old 08-20-2012, 04:19 PM
Kdubag's Avatar
Kdubag Kdubag is offline
Vehicle: 2010 Ram Crew Cab
Trim Level: Lone Star
Color: Mineral Gray
Rep:15
Kdubag is on a distinguished road
Originally Posted by dkerr24 View Post
Tested and confirmed. The FOB will start the vehicle, even if the battery has been removed from the FOB.
To give myself some spare keys, I bought 2 chipped metal keys from a online reseller, took the keys to my Dodge dealer, who cut the keys to fit my locks and they programmed the key to start my truck.
Cost:
$20 for each key
$20 to cut/program them
The key will unlock the door/tailgate and will start and run the truck. The key has the same notch that the FOB has that allows it to fit in the ignition.
Darin
Where did you get these said keys? Do you have a link to the online dealer? This would be nice to have if I decide to get a viper or clifford remote start/security system for the truck. So I don't have to carry to bulky fobs.
**Nevermind. Picked up two from ebay at 13.xx a piece.
Old 08-21-2012, 10:05 AM
dkerr24 dkerr24 is offline
Vehicle: 2011 Dodge Ram
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
ikeyless.com/dodge is where I found mine. They are the same key as the one pictured above in this thread.
Darin
Old 08-21-2012, 10:11 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Just FYI, the key fob doesn't even have to be in the ignition, just close by. The ignition somehow senses the key fob(hence it has to be programmed correctly for your truck) and then when you turn the ignition it starts and runs. You can actually just hold the fob near the ignition and stick your finger in the ignition and turn it with your finger and it will work.
For those that leave a key fob in the truck(dead battery or not) someone could break your window, put the fob in the ignition and drive away. Battery isn't required in the fob.
The metal key inside the key fob is for if the battery in the fob dies and you can't unlock your doors electronically.
Sean
Old 08-22-2012, 03:16 PM
Color: Grey
Rep:41
I must apologize I just tried the Fob without the battery and the truck started right up. I don't know if that is good to know or not?
Old 08-22-2012, 03:19 PM
snrusnak's Avatar
Rep:1385
Yeah you don't need to have a battery in the fob to start the truck. The battery in the fob is only to use the remote control(lock/unlock the doors from 20ft away, etc).
That's why I said it's not a good idea to leave a fob in the truck even without a battery, as someone could break the window and simply drive away with the fob in the ignition.
I believe it is the same type of technology used in the new epass/sunpass/ezpass (whatever) things that they stick on your wind shield(with no battery) to pay tolls, so you can keep driving without stopping and it automatically pays it from your bank account. The sticker on the wind shield has no battery but somehow the thing that sends a signal recognizes it and identifies it.
Sean
Old 08-22-2012, 03:38 PM
Color: Grey
Rep:41
I have to say I was very surprised. Where I was when I put the new battery in I think was pretty safe from the truck being stolen. Somewhere else defiantly a different matter.
Old 08-22-2012, 04:03 PM
Rep:2657
the FOB is for remotely starting or unlocking your vehicle
it also sets the ALARM
without the FOB someone could enter your vehicle by whatever means, steal everything in it, but supposedly they can't start the vehicle & drive it away
take a penlight & look into where your FOB fits into the ignition, there is really nothing there
The little release mechanisms used to break off inside there, the manufacturer had to do a recall on many ignitions, when they first started using the FOBS
