Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 08-15-2012, 09:51 PM
aporter2403 aporter2403 is offline
Vehicle: 2007 Dodge Ram
Trim Level: unk
Color: silver
aporter2403 is on a distinguished road
Default chime issue
I have a 2007 Dodge ram diesel. the chime is sounding as if the door was open or the seatbelt was off, however all are closed.., any ideas??
Old 08-15-2012, 10:15 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
How many chimes? BTW this is the 1st Gen section and you'll get a better response if you post the issue under the section specific to your vehicle.
Old 08-24-2012, 09:13 PM
Oldy but goodie Oldy but goodie is offline
Vehicle: 1972 dodge 200
Trim Level: base
Color: blue/silver
Engine: 1992-1993 318ci (5.2L) Magnum V8 230 hp 280lb/ft
Oldy but goodie is on a distinguished road
But one of us would just pull the thing out and throw it away.
Old 09-03-2012, 11:05 AM
moparornocar72's Avatar
Rep:630
It's probably the switch gone bad or grounded out, I would check to see what kind of volts are coming off that switch when u push it in and when it's out.
14.268 @ 95 MPH Full Trim
Old 09-03-2012, 11:15 AM
Vehicle: 95
Rep:1776
Well the reason I ask "How many Chimes" is because USUALLY the number of chimes is an indication of what is malfunctioning. There are different number of chimes/patterns depending on it the seatbelt is not latched, you left the headlights on, door is open etc...
However maybe you would be better off just ripping it out of your 2007 ram diesel as suggested, because that wouldn't cause any problems. I'm sure that would solve your chime issue. While you're at it maybe take a hammer to the injector pump? You know how primitive the electronics are on these things. There's even a couple of sticks in the dash board instead of a lighter.
