Turbo mania by MGH - Page 17 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 07-18-2013, 01:52 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
Originally Posted by mikennrg View Post
Thanks for sharing. Those numbers are very impressive. I wonder how much HP the stock tranny would hold if you had a digital boost controller to limit HP in the lower gears.
the stock trans is on borrowed time once you start modding. It's hard to put a hp number on it because even N/A guys are blowing it up too.
Old 07-18-2013, 03:44 PM
mikennrg mikennrg is offline
Vehicle: 2012 RCSB Express
Rep:97
mikennrg will become famous soon enough
I agree. My though process was that you could prolong the life by limiting HP in 1st and 2nd which seem to be the weakest points in the trans.
I love my truck, but my biggest disappointment is the fact that the transmission in my Civic is capable of handling more HP than my truck.
Old 07-18-2013, 04:04 PM
CHVYKLR's Avatar
Rep:252
that's pretty much what Ram did with their tuning. They introduced "Torque Management" to prolong the life of these transmissions when the HEMI hp was upped to 390.
Old 07-28-2013, 07:59 AM
NolaRam's Avatar
NolaRam NolaRam is offline
Vehicle: 2009 Ram 1500 Crew Cab TRX
Trim Level: TRX
Color: Detonator Yellow
Rep:29
NolaRam is on a distinguished road
I know you aren't asking but I think you'd come out better building your current setup. The Eagle heads already flow awesome. Go all forged and stroke your 5.7 to whatever then add F/I. You can adjust the boost to come out at whatever hp level you want. $10k just for a longblock is a lot of $$.
Thinking of a drop in set to forge the rotating assembly. Just maybe use a 6.1 SRT crank and new rods and pistons? How much wider can I go piston wise on the 5.7? 4.14? what's that get me to about a 5.8L displacement?
Old 07-28-2013, 12:24 PM
Rep:3347
6.1L crank uses a 32 tooth reluctor wheel and the new vvt 5.7L uses a 58 tooth, Manley does offer a 6.1L crank with a 58 tooth reluctor wheel but you'd need to pick up a snout spacer for the 5.7L timing set. There's not much room to over bore the chambers, and doing so reduces the number of potential rebuilds if something goes wrong. I have a 349cu in vvt block with a 6.1L crank and the bore is 3.937", the engine builder had to swap reluctor wheels and I just put the engine in this week and so far we haven't been able to get it to fire up, but I'm hoping it's just a startup tune issue.
Old 07-28-2013, 04:44 PM
CHVYKLR's Avatar
Rep:252
MGH is sourcing that 6.1 Manley crank and we don't plan to bore unless needed.
Old 07-28-2013, 05:40 PM
Rep:3347
I would agree with Mike on not boring it. I'm wishing my block was able to be rebuilt if required, but that's what I get for the price I paid on this block. I'll just build up my old block with a small stroker assembly
Old 07-30-2013, 11:34 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Just swap to a pre vvt block... Everyone's doing it! Well not everyone... I think the advantages of a pre VVT block out way whatever avantages you think you will get with a VVT motor... Show me a timeslip of a VVT car that is faster than the heavy hitting pre vvt block guys? You cant cuz those guys are running almost a full second faster or more... Easy to Tune, Big Cams, More Power, Faster Slips...
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 07-30-2013, 11:55 AM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
Mine's no longer VVT!
2012 R/T 392
Old 07-30-2013, 12:50 PM
RamTex's Avatar
Color: Stone White
Rep:366
Thats was smart right there!
