Old 08-16-2012, 01:48 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Awesome! Your truck is gonna fly. So who is putting the transmission together? The 68rfe gearset in the 545rfe will be great. Also stronger. Your basically going to have a 66rfe. I didn't know this swap was possible.
Sean
Old 08-16-2012, 02:25 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
My truck is Mike's donor truck and we worked it out to where he could have it for a couple months. He is mocking everything up and inventorying everything needed for a kit. Like he stated in his build thread he only uses top notch parts...Garrett, Tial, Bosch, AN fittings, 304 stainless steel, etc. and of course there are tons of options. I'm getting the hot side all coated in black and I was going to stay with the 5.7 intake until Timmy found me the 6.1. Anyone considering a kit should seriously PM MGH with questions. I will continue to post pics to try and show the build quality and his attention to detail.
WRT to the 68rfe internals I'd have to refer you to Mike on that one. The problem with the 545rfe is the frictions not the gears.
Old 08-16-2012, 02:35 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
The 6.1 will be way better for the turbo setup....won't be plowing the plastic apart
Do you guys have any idea of how much the completed kit will run? I would love to have this setup after I get my drivetrain stuff setup and the heads/cam done
Old 08-16-2012, 02:36 PM
snrusnak's Avatar
Rep:1385
I don't know a whole lot about the transmissions I just know the 68rfe is the diesel transmission and the 66rfe is basically the 68rfe gearset in a 545rfe case and is for the hemi n the 2500's. That gearset from the 68rfe or 66rfe is a much better gearset than the one in the 545rfe(ratios are spread more evenly, lower first gear, and taller final gear), and it is supposedly stronger which should be obvious since it's from a 2500 ram not a 1500 ram. I'd be really interested in more info on the transmission work, and cost, as I'd be interested in it myself just for the better ratios. Thanks and good luck with the truck!
Sean
Old 08-16-2012, 02:47 PM
916Timmy's Avatar
Rep:1443
I'm interested in the trans stuff too
2012 2500 and 3500 models with gas engines received the 66RFE, a hybrid of 68RFE internals (including the gearset) packaged in a 545RFE case.
Old 08-16-2012, 02:49 PM
AllUCIsTailLights's Avatar
AllUCIsTailLights AllUCIsTailLights is offline
Vehicle: 2007 Dodge Ram
Trim Level: 1500 Big Horn
Color: patriot blue
Rep:39
AllUCIsTailLights is on a distinguished road
^^ i didnt know this as well..i was thinking about getting a built tranny for my twin turbo set up from a company out of phoenix, but can i do this swap as well for my 3rd gen 545rfe?
Old 08-16-2012, 02:57 PM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
The strength of the 68 comes from the number of frictions it uses over the 45. I have found a way to put even more frictions in the 45 then come in the 68. I also rebuild the pump so that it produces up to 250 psi and modify the valve body. When you put all that together you have a trans that can handle more TQ, that shifts hard, but not harsh.
Old 08-16-2012, 03:00 PM
snrusnak's Avatar
Rep:1385
Very cool. A little over my head but I get the idea lol. Are you able to swap the better gear ratios from the 68/66 into the 45? What's a rough cost for this if you don't mind sharing?
Sean
Old 08-16-2012, 03:06 PM
mgh's Avatar
mgh mgh is offline
Rep:27
I can swap gear sets, but we do not have the tuning capability to tell the TCM that the gear ratios have changed. Without that tuning, you would get a gear ratio mismatch trouble code....
Old 08-16-2012, 03:09 PM
CHVYKLR's Avatar
Rep:252
I'd PM Mike becuase like I said there are a lot of options depending on which direction you want to go. Your hot side would most likely be the exact set up I'm getting since you are a 2wd.
