Old 08-16-2012, 03:11 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
I can swap gear sets, but we do not have the tuning capability to tell the TCM that the gear ratios have changed. Without that tuning, you would get a gear ratio mismatch trouble code....
Thanks for the info. That's unfortunate, I'd love to have the other ratios, much better IMO. Personally I don't need a stronger trans for my 4.7L that is NA but good to know you can do this for the other guys.
Sean
Old 08-16-2012, 07:51 PM
FrostKing's Avatar
FrostKing FrostKing is offline
Vehicle: 2003 Dodge Ram
Color: Graphite
Rep:21
FrostKing is on a distinguished road
Build a front mount kit. You will get fed up and build one eventually, so you might as well just start there. Follow the lessons other's have learnt the expensive way.
2014 White Crew Sport 4x4 8-speed 3.92 gear
Sold: 2003 RCSB 2WD
6.4L Hemi - Turbocharged, Alcohol, Nitrous
Old 08-16-2012, 08:24 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
do you have any pics?
Old 08-16-2012, 08:29 PM
snrusnak's Avatar
Rep:1385
nothing wrong with a remote mount... just keep away from puddles
Sean
Old 08-16-2012, 08:33 PM
CHVYKLR's Avatar
Rep:252
the filter will be mounted over the fuel tank
Old 08-16-2012, 09:29 PM
mgh's Avatar
mgh mgh is offline
Vehicle: 2009 Dodge Ram
Trim Level: Sport RCSB
Rep:27
mgh is on a distinguished road
I have been running a pair mid-mounted for 2 years with zero problems.
Please elaborate on the lessons learned by others...
Old 08-19-2012, 04:32 PM
moparornocar72's Avatar
Rep:630
Loving this thread!
14.268 @ 95 MPH Full Trim
Old 08-19-2012, 11:01 PM
FrostKing's Avatar
Color: Graphite
Rep:21
1. The turbos will create enough heat under the box to melt a bed-liner or bedrug.
2. Rear mounts will also be more laggy than an equal size front mount. This can be counter-acted by running a smaller turbine, which in turn creates huge back pressure at higher RPMs. Rear mounts will not be as capable of both high and low RPM performance.
3. Relying on a oil return pump is also a ticking time bomb. Even with the pump working perfectly there are situations where oil with get past the turbo seals and into the piping. i.e.. Parking on a moderate to large slope. The life of the turbo or engine relay on a small electrical motor and fuses that generally are never 100% water/corrosion proof.
4. Rear mounts also make a water cooled turbo very impractical and this is the only way to have a long lasting setup.
5. In below freezing weather, condensation will build up in the oil return lines and the crankcase will become contaminated with water in very little time. (I don't have a clue how this one happens, but myself and 2 others have experienced this)
6. Any crankcase pressure at all will stop flow from your scavenger pump and all the oil will go out the tailpipe. The same crankcase pressure on a front mount with have no effect.
7. The long oil supply line can be easily damaged or restricted ruining a good turbo. ($1800 in my case)
8. Rear mount setups have nothing for the viewing public.
I've run 3 different rear mounts on this truck, since 2006, and converted to a front mount last fall. I couldn't be happier.
Sold: 2003 RCSB 2WD
Old 08-20-2012, 09:10 AM
CHVYKLR's Avatar
Rep:252
thanks for the reply and I appreciate the insight. sounds like you've been thru a bunch a different setups.
did you look at my picture in post 20? I'd be willing to bet that my hotside is no longer (if not shorter) than a front mount that also runs off stock exhaust manifolds/JBA shorties. I've compared my hotside to twin setups on Grand Cherokees SRT8s and some single LX & mustang setups and I have less hotside piping. I'm not sure how else to convey that this isn't a rear mount setup...but a midmount at best. Once everything is complete I'll post a video of the whole system.
I've also included another picture here becuase the bottom of the area chosen for the turbo (under the cab) comes lined for heat protection from the factory. As a backup I've also ordered a 12"x24" piece of Thermo-bac to double up that area. If you don't think that barrier would be sufficient I could always throw a turbo blanket over it too. thoughts?
this will be a Florida truck so hills/inclines and freezing temps won't be factor but I guess I'll have to wait and see.
Old 08-20-2012, 10:53 AM
FrostKing's Avatar
Color: Graphite
Rep:21
That looks like a better choice than a traditional rear setup. If possible, design the piping to allow transmission removal without pulling the turbo out. (you will appreciate this later) I still think a scavenger pump is unnecessary in a Ram as we have tons more room under the hood than a LX or Jeep.
Sold: 2003 RCSB 2WD
