Losing my mind!!! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 08-16-2012, 12:04 AM
RigGeo RigGeo is offline
Vehicle: 2007 Dodge Ram
Color: Blue
RigGeo is on a distinguished road
Default Losing my mind!!!
Sorry about this being my first post on this site, but the search for its solution has actually turned me on to this site which is really cool!
My issue:
I washed my truck (2007 Dodge Ram 1500), as I always do after a trip, and now my drivers side DRL and high beam no longer works (low beam is still operable). I've dried out the connection, changed bulbs, still doesn't work.
I've checked voltage to the connector without the truck running, light switch on and high beams on, and I've got 11.1V going to the plug thru both wires tested to the middle black ground wire.
My curiousity led me to test the passenger side where the DRL and high beams work, 11.9V there. So why is it only 11.1V on the driver's side?
I'm stumped, I'm usually pretty sharp with electrical issues, but this baffles me. What scares me is I've read threads that say "replace your TIPM" which isn't a "do it yourself" thing. But if thats what it is, so be it.
Any help or insight would be greatly appreciated!
Ryan
Old 08-16-2012, 09:50 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
Have you checked the individual fuse and relay for the driver's side? There should be independent fuses in the relay center under the hood. R/S High/Low, L/S High/Low. The left side low may have simply blown.
(P.S. I'm constantly told that I can't lose something that I never had)
Old 08-16-2012, 11:00 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Now that is weird since you say you have voltage at the actual connector without the truck running. I would test it again with the truck running. I would not think that 11.9 v.s. 11.1 would not be enough to have it not work. Just my 2 cents.
sales@revelperformance.com
Old 08-16-2012, 01:41 PM
Color: Blue
Thanks for the replies!
I'll double check the voltage with the truck running and post up what I find.
Ryan
Old 08-16-2012, 06:39 PM
Color: Blue
Ok so with the truck running I have 13.9V running to both passenger and drivers side bulb connectors with high beams on. Thinking I'm a moron, I replaced the bulb with the one that was working from the passenger side.....still no high beam on the drivers side! Soooo I disconnected the battery for 20 min thinking something may just reset itself....no luck, same thing, no drl or high beam on my drivers side.
I'm getting voltage thru the connector.....so I bent the pins down on the bulb to make better contact with the connector.....still nothing. I'm totally stumped now, I guess my next step will be to replace the connector/plug and see if that may help.
Ryan
Old 08-16-2012, 08:04 PM
AFMEDIC's Avatar
AFMEDIC AFMEDIC is offline
Vehicle: 2002 Dodge Ram
Color: Maroon
Rep:18
AFMEDIC is on a distinguished road
Have you checked the ground? These trucks have ground side switched headlights so they should always have power to the light. 0.8 volts isn't enough to make it not work, but it doesn't sound like you have a power problem. When you turn the high beams on it completes the ground circuit. Check a wiring diagram for where the wires run to and which connectors they are in. Hopefully that gets you started in the right direction.
Welcome!
If Guns kill people, then pencils misspell words and spoons made Rosie O'Donnell fat...
Old 08-18-2012, 04:01 PM
Color: Blue
Will check that today, thanks for the help!
Ryan
Old 08-26-2012, 01:33 AM
FreddyKrueger FreddyKrueger is offline
Vehicle: 2005 Dodge Ram
Trim Level: Base
FreddyKrueger is on a distinguished road
One of my good friends, an older mechanic, thought me that with electrical problems first thing people omit is the ground. So, I always check the grounds when the fuse is not the problem. It just makes too much sense.
Then again, I am new to Rams so... Let us know.
Old 09-09-2012, 12:31 AM
erickm45 erickm45 is offline
Vehicle: 2003 Dodge Ram 2500
erickm45 is on a distinguished road
Default high beam not working
their are 4 drivers used to turn the headlamps on and off 1 driver for each side low beam and 1driver for each high beam. the drivers are part of the fuse pannel. the headlight switches send a siginal to the computer which in turn turn the drivers on or off. get a wireing digram and trace the wires back to the drivers.
