Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 08-08-2012, 11:37 AM
PunisherRam PunisherRam is offline
Vehicle: 2005 Ram 1500
Trim Level: Quad cab SLT
Color: Deep Molten Red
PunisherRam is on a distinguished road
Default No 4x4 indication
I have an 05 ram 1500 and when engaging the 4x4 in either lo or hi i get no indications on the dash. It feels like it is engaging. I have checked fuses and tried a reset of the ecu/tcu but still nothing. Any help out there?
Old 08-09-2012, 12:21 AM
crazychevy88 crazychevy88 is offline
Vehicle: 2004 dodge ram
Color: silver
crazychevy88 is on a distinguished road
do you have a manual or electronic shifter for the t-case? I have a manual and the same problem, theres probly no tcu code because the sensor is in the t-case. I think thats what is wrong with mine, just havent bother to test that theory yet since I know it engages when I pull the lever (I know because I was buried up to the frame and both axels were spinning). If thats what it is let me know so I can get my light to come on to!
Old 08-09-2012, 12:45 AM
Mine is the manual type...i found a site on the net that had a pretty good breakdown of how to trouble shoot this issue and I got lucky. All I had to do is engage 4lo or 4hi, when you do this turn your wheels left and right and give it a little gas. Did that and everything is all good. I have the page on my other laptop and will post it for you tomorrow morning. From what I was reading, the no light indication means that the axles are in different positions and doing this aligns everything up. Hope this may help!
Old 08-09-2012, 12:54 AM
http://www.ramforumz.com/showthread....d=1#post861388
Sometimes, the 4WD light stays on, or fails to come on. This is a great indicator. What it means is that there is a difference in speed between the two axle ends, and the vacuum can't move the collar. Burping the throttle, twisting the wheel side to side, or shifting the 4WD again generally releases the pressure.
That is what I did on mine and now it works perfectly.
Old 08-09-2012, 11:51 PM
Color: silver
i'll give that a shot tomorrow, thanks!
Old 08-14-2012, 09:41 PM
Color: silver
no luck for me, did you have it movin when sawing the wheel back and forth? were you power breaking toget the rpms up or in neutral?
Old 08-16-2012, 11:52 AM
live2ride live2ride is offline
Vehicle: 14 1500 5.7 CC 6.4 8sp
Color: Maximum Steel
live2ride is on a distinguished road
x2 same issue and no luck fixing... everything seems fine in 4x4 just no light.. starting to think its just a burnt light in the dash?
2005 dodge ram crew cab 1500 5.7L hemi- cat back Gibson exhaust, Superchip, Intake spacer, BBK CAI, 4" Rancho Susp lift, 17x9 -8mm ion alloy 133 rims with 370-70 terra tracs SOLD
2014 Ram 1500 CC longbox hemi big horn, 3.92 gears 121L tank
Old 08-16-2012, 09:53 PM
Color: silver
not a burnt out light live2, if anylight goes out in my truck, interior or exterior I have an indicator for it, im sure your 05 does to.
Old 08-17-2012, 12:19 AM
good point. wierd that we dont get an error code for the 4x4 light not coming on... I def know its engaging. and seems to be a common problem from what I see
