Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Ram Vans
Dodge Ram Vans For discussion of Dodge Ram Vans. Please use our existing technical areas for driveline discussion, etc.
Old 08-17-2012, 08:46 AM
van tough van tough is offline
Vehicle: 94ram250 van & 96ram 2500van
Trim Level: the 94 power everyth
Color: phantom gray
van tough is on a distinguished road
Default ram van
Hello , from Woodbridge Va
I'm very new,....and trying to place some posts about my van
94 ram 250 w/ 318 . Getting ready to rebuild the motor a& trans and I am trying to find some good suggestions over the next couple of months
thanks
Old 08-19-2012, 05:12 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Originally Posted by van tough View Post
. . . 94 ram 250 w/ 318 . Getting ready to rebuild the motor a& trans and I am trying to find some good suggestions over the next couple of months
1st question is what's your budget? 2nd one is what do you want to accomplish?
There are LOTS of things you can do to a 318 to really "wake it up" for more power & better fuel mileage both, but the best options are expensive. Same goes for the transmission (assuming automatic), but getting an aftermarket valve body and/or shift kit isn't really all that expensive -- if you want to change the torque converter, that's a different matter.
And I always say "think system" rather than individual parts -- the best parts $$$ can buy won't do you any good if they're not designed to work together. For example, you can put 360 heads on a 318, but since the combustion chambers are larger your compression ratio will go down, so you'd need new pistons to bring it back up.
Edelbrock makes a really neat EFI system for a 318 with 360 heads which will give you a lot more power & better fuel mileage too, but it definitely ain't cheap! But if you can get away with it (inspections, emissions), a good aftermarket intake manifold & a Carter AFB 4-barrel carb will work great too & not "break the bank". Headers & a good dual exhaust system isn't all that expensive either -- unless you have to use catalytic converters (for inspections).
So you have LOTS of options & really the only limiting factors are 1) what you're willing to spend & 2) which combination of parts will work together to accomplish your goal.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
