Old 08-17-2012, 09:48 AM
RAM1961 RAM1961 is offline
Vehicle: 2000 RAM 2500 V-10 Quad 4WD
Trim Level: SLT Laramie
Color: Maroon
RAM1961 is on a distinguished road
Default ABS warning light, brake warning light and service 4WD
Hi,
Have a 2011 2500 MegaCab. Yesterday, the three warning lights came on out of the blue as I was heading home. After a few minutes, they all went back off and didn't come on again at all during 45 min. drive home. This morning as I headed back to work - they all came back on again.
Not sure if there's any correlation here - Saturday, I got my other truck stuck up at a little lake two miles from home pulling boat out. A guy came over to help, but not a long enough chain - he went back to his boat and promptly got stuck. So his wife took me down to get this truck (2011), and I pulled him without issue. I asked her to help me back up so I wouldn't hit any rocks as it was getting dark. Well, sure enough I heard her say STOP and a THUNK at the same time. I had punched a hole in bottom of rear diff. cover. I quickly went and pulled my other truck out and had my wife drive this truck home slowly. Still had oil in it when she got home and no funky grinding noises, etc. Replaced cover Wed. and no apparent issues by sight or feel in the rear diff. and no other damage underneath from back to front. These warning lights did not go on yesterday (Thurs.) all the way to work - just when I was getting ready to go home. Only other thing I noticed yesterday was when I went down to bank at noon, as I slowed to a stop, could feel the abs vibration in brake pedal just slightly a couple of times. Then it went away too and didn't happen again. All brake lines look fine underneath the truck.
Any suggestions, or do I just need to take it in to dealer. Thanks in advance.
Old 08-17-2012, 05:27 PM
Color: Maroon
They turned on again at lunch when I went down to post office, but then turned themselves off while I was driving. Maybe there is a loose connection - guess I'll crawl under again tonite. I made a second trip about an hour ago around town and they didn't come on at all.
Old 08-17-2012, 06:01 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
I'm not 100% sure where on the 11's it's hiding but I'm positive there is a wheel speed sensor somewhere on the rear diff that could be causing your issue.
Hopefully someone that knows will chime in shortly.
Big Red my old 2011 Sport
Old 08-21-2012, 12:27 PM
Color: Maroon
It must be a connection issue - none of those warning lights came on at all the past two days. I still don't know where it is - checked on top of rear diff. and everything seems connected there. They always come on together - maybe I should check by transfer case.
Anyway, they didn't come on at all - but I stopped for fuel this morning, and sure enough, they kicked on as i left station......
Old 08-21-2012, 01:03 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Sounds like a wheel speed sensor issue/connection issue. Something probably was damaged in that hit.
Sean
Old 08-21-2012, 08:13 PM
wbowyer wbowyer is offline
Vehicle: 2011 Dodge Ram 1500
Color: Inferno Red
Rep:71
wbowyer will become famous soon enough
I have the same lights minus the 4wd indicator (mines a 2wd) and my truck has never been off pavement. Nobody has been able to explain this to me from the dealership, etc.
Old 08-22-2012, 11:35 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Let us know how you make out and please keep us updated.....
