Old 09-10-2012, 06:34 PM
Commando57's Avatar
Commando57 Commando57 is offline
Vehicle: 2011 Dodge Ram 2500HD
Commando57 is on a distinguished road
Oh and to the OP, my GPS shows that the odometer is off quite a bit. GPS shows 1.16 miles for every 1 mile on the odometer. The speedometer shows 66 while GPS shows 70.
Old 09-12-2012, 01:59 AM
Trim Level: sport
Color: green
Rep:657
huntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to beholdhuntergreen is a splendid one to behold
you need to have the dealer flash the ecm so it "knows" you put some larger tires on it. you will then be able to calc. your mpg with corrected numbers. you will find you lost some mpg, but not near as much as you think. i would do this before i traded out my tires.
bad gas mileage, gas milage, oxygen sensor, re-ger
