Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > V6 Specific Topics
Old 08-18-2012, 10:10 PM
pitterpatter pitterpatter is offline
Vehicle: 2000 Dodge ram van 6 cyl.
Color: MAROON
pitterpatter is on a distinguished road
Default Differential info
Hello,
I am new to forum. I was wondering if anyone could please help me. I am removing differential cover on 2000 dodge ram van. The two tags on cover says 0690 on one and 3.5 on other. I know the 3.5 is ratio. It has 10 bolt pattern. The auto retailer gave me 80/90 gear oil. Didn't know if it is LSD or not. I don't think it is. I bought additive just in case. In manual it shows different types and is non specific. The manual shows another ID tag I may have missed. I will check in morning. A mech shop told me I have a bad bearing there making grinding noise. I remember hearing this noise from day one of tire replacement. When I took it in for front end alighnment they told me that. I just wanted to inspect gears and change oil.
Old 08-19-2012, 04:28 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
Originally Posted by pitterpatter View Post
. . . The auto retailer gave me 80/90 gear oil. Didn't know if it is LSD or not. I don't think it is. I bought additive just in case.
If the label says something like "This product is suitable for use in limited-slip differentials" the product has the additive -- but if language like that is not on the label it does not have the additive.
If you've got a bad bearing the only thing you can do is remove the differential, take it apart & replace the bearings. You will probably not be able to see the problem just by draining the gear oil & pulling the cover off.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 08-19-2012, 07:48 AM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
If it's an axle bearing you're not going to see it from inside the cover. You'll have to jack up each rear wheel and check it for movement
Old 08-19-2012, 08:15 PM
Color: MAROON
I was just changing oil as a preventative maintenance, and look at gears. But I will raise and check axle bearings also. I was wondering if this is a limited slip differential so I don't put in the additive when it does not call for it. Have not had a chance to work on yet, it has rained for days. Thank you for all replies, it's much appreciated.
Old 08-19-2012, 08:33 PM
Vehicle: 95
Rep:1776
I add friction modifier to every rear I work on as a rule of thumb. A tube is $7 I think and worth it no matter which rear you have.
Old 08-19-2012, 09:42 PM
Rep:57
You should be able to tell by looking @ the differential (with the cover off) -- most LSD's have clutches which non-LSD's do not have. And if you put the additive in a non-LSD differential it wouldn't hurt anything -- the additive is a "friction modifier" that works on the clutch plates & if there aren't any it doesn't matter.
Old 08-20-2012, 10:14 AM
Color: MAROON
Thank's for the info. I read the bottle and it says it can be used in various types as you all stated. I should have read the bottle first. I will add to oil. That's embarrassing. Brake line leaking on wife's car. After I fix hers I will do differential,serpentine and charge ac up. Thank you for all responses. I am trying to finish repairs before I go offshore to work for two weeks. Have a great day. It's good to know there are people out there helping each other. I hope I can return the favor. The internet is a great source of information. Although it takes intelligent people on the other end of the keyboard.
Old 08-21-2012, 07:56 PM
Vehicle: 95
Rep:1776
Here's another hint. When you bleed her brakes, and if you don't have a helper, put a small rubber hose snugly over the bleeder. crack it loose and put the hose in a bottle of brake fluid with the end below the level. When you pump the brakes it's blow the air (bubbles) out but can only suck fluid back in. One man bleeder.
Old 02-11-2014, 10:09 PM
montrese04 montrese04 is offline
Vehicle: 99 Ram 1500 4WD w/5.9
Trim Level: dont know maybe ST
Color: yellow (for now)
Rep:19
montrese04 is on a distinguished road
i know this thread is old but I wanted to say thanks to warlock for the lil trick for one man bleeding of brakes.
Old 02-18-2014, 09:13 PM
Vehicle: 95
Rep:1776
Did it work out for you okay as I had suggested?
for gettin' back to us.
