97 Ram rust repair - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 08-20-2012, 02:43 PM
andyvillen's Avatar
andyvillen andyvillen is offline
Vehicle: 1997 Dodge Ram 2500
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
andyvillen is on a distinguished road
Default 97 Ram rust repair
Well I figured I would make a thread of my repair and mods I'm doing on my truck. I'm sure by the time I'm done everything I wont have a girlfriend or friends haha
You can see the repairs I'm doing to the inner rocker and about 4" of the floor pan and part of the front body mount.
I also repaired a set of used fenders, i had to replace a good bit of the lower rear. in the picture you can see that i shaved the antenna off because it looked like someone took a hammer to get it off.
Andy - I'd rather be cummin than strokin
Old 08-20-2012, 08:24 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Wows that's some rust. Well look at it this way when your done you can use the truck to find new friends and get a new girlfriend.
Old 08-20-2012, 08:30 PM
Vehicle: 95
Trim Level: Cloaking
Rep:1776
FYI thumbnails are permanent. Once you fill up on them there's no way to get rid of them and you can't post any more pictures...unless you use a second party like Photobucket and paste them.
I feel your pain. Did complete rockers on both sides and cab corners. Back half of the frame from the cab back, fenders, hood, bed. It'll come together.
Old 08-21-2012, 02:30 PM
JeffreyCH's Avatar
JeffreyCH JeffreyCH is offline
Vehicle: 1996 Dodge Ram 1500 4x4
Trim Level: SLT sport
Color: red
JeffreyCH is on a distinguished road
Good thread I'll be watching this one, I have to do the drivers side rocker on my '96. Mines not near as bad as that, but the process should be similar.
Old 08-26-2012, 01:20 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 2005 Dodge Ram 1500
Trim Level: SLT w/ Sport Pkg
Color: Sollar Yellow
Rep:103
I like what I see so...subscribe!
Old 08-26-2012, 10:39 PM
andyvillen's Avatar
Thanks Warlock III for the info.
made a bit of progress on the truck the last few days.
painted the inner fenders with this Chassis Saver paint from
http://magnetpaints.com
Great stuff! i put this stuff on with a foam brush!
I have the rocker and cab extension welded in.
and a big patch to the floor, I know the rest of the floor looks bad but its just the inside. for some reason the carpet insulation was wet. the truck has been inside a garage for a year and wasn't driven for 2 before that.
also replaced the inner and outer door bottoms..... not a job I would do again and not with the junk replacement panels I got. Nothing lined up and from the front of the door to the back the parts were 1/4" to short.
Old 09-05-2012, 06:00 PM
JeffreyCH's Avatar
Color: red
Looking great so far....how many friends it cost ya so far
Old 09-12-2012, 11:17 AM
andyvillen's Avatar
well there's been progress albeit very slow. Mostly in part to this!
But i finished the floor up and painted it with the chassis paint.
did some sloppy body work on the door and painted the door jam and inside the door with the same paint.
also had a really hard time getting door pin kits, the kit that Help! company makes not really good. i used 2 packages and drilled everything out to fit. i hope it works... I'll be hanging the door tomorrow and installing the fender.
Old 09-12-2012, 05:19 PM
Phatninja55's Avatar
Phatninja55 Phatninja55 is offline
Vehicle: 1994 Dodge Ram 1500 Reg. Cab
Phatninja55 is on a distinguished road
That looks really good. Nice progress.
Old 09-12-2012, 07:06 PM
Vehicle: 95
Rep:1776
Looks like it's coming along nicely.
