New to Dodge Diesel looking for mod advice - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel
Custom Dodge Ram Performance Mods - Engine - Dodge Cummins Diesel Discuss modifying your Dodge Ram with Performance Parts and Accessories!
Old 08-20-2012, 07:07 PM
tmccue tmccue is offline
Vehicle: 07 Diesel 3500
Color: silver
tmccue is on a distinguished road
Default New to Dodge Diesel looking for mod advice
hey guys i just joined the site. i just traded in my Ram hemi for a 07 Diesel 3500 and love it already. im looking to get some mods. i want to get a programmer and have been reading the archive notes and everyone seems to give different opinions. i just plan to do simple mods intake and i want stacks for exhaust.
If anyone could give me advice on stacks, Intake and a programer it would be much appreciated.
Thank you
Old 08-20-2012, 10:57 PM
06Rammin 06Rammin is offline
Vehicle: 2006 Dodge Ram 1500
06Rammin is on a distinguished road
Which engine do you have the 5.9 or the 6.7? There are alot more mods for the 6.7 (deletes and stuff) compared to the 5.9.
Old 08-20-2012, 11:26 PM
HEMI450HP HEMI450HP is offline
Vehicle: 2010 Dodge Ram 2500
Rep:69
HEMI450HP will become famous soon enough
The 5.9 actually has much better aftermarket support, but you will need to delete the DPF and EGR to run a tuner on a 6.7.
Let us know which motor you have, and we can get you setup with some fun mods that will make your new truck a blast to drive.
Old 08-21-2012, 11:49 AM
Color: silver
I do have the 6.7 and at the shop now looking at a stack kit
Old 08-21-2012, 07:07 PM
Color: silver
well here is what i have in mind so far. i want to do the stack kit however i need to perform the DPF delete which seems to be a pain in the ass. if anyone had recomendations so far on how to do this i would apprieciate it. also im looking to buy the EGR delete kit from H&S seems like a clean kit with billet aluminium covers. However not sure on what tuner to buy. it seems as tho i have to perform all the deletes and tunes before really even attempting to put the exhaust system on. if this is true or not please let me know
Thank you
Old 08-21-2012, 07:22 PM
Rep:69
That is true. In order to run a programmer, you will need to delete the EGR and DPF...and if you delete the EGR and DPF, you will need to have a programmer. They all work hand in hand.
The power and mileagegains after these 3 mods is incredible though. I highly recommend all 3.
Old 08-21-2012, 11:07 PM
Color: silver
are there any tricks or recomendations for doing the deletes? i plan to buy the EGR delete kit from H&S but my only question for the DPF is what do i do with the hard lines the go all the way to the DPF do i just remove them or do i have to cap them off?
Old 08-22-2012, 06:01 AM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:80
You can run a programmer with the DPF intact, but IMO it's not worth it. Edge makes one for DPF intact vehicles, but ive yet to hear anything good about them (limited performance gains, more regens,etc)
I highly recommend the H&S Mini maxx or black maxx. You can use them with or without the DPF/EGR etc. Tunes are easily downloadable (to the programmer and to the truck), easy to use, gives you the option to monitor 4 things at once (I have boost,EBP,engine temp, and tranny temp displayed on mine) and has 3 power levels under two tune banks ( with advanced turbo tuning or without). You can also add Overdrive software for your transmission ( tuning for your tranny to prolong its life).
As far as the exhaust goes.. Just zip tie the lines up and out of the way once you remove the stock exhaust. If you do the work yourself, have a friend there to help you. It will make removing the stock exhaust and installing the new a lot eaiser.
As far as the intake I wouldn't bother with it unless you are making over 500hp(and in that case you will want to add studs, and a seperate savings account started for your transmission to your list of mods), the stock one has been proven to be efficient up to that power level, an i have yet to see an aftermarket intake perform better than the stock one on a mildly modified (exhaust and tuner) 6.7. I have searched a ton and the only changes that you will notice are a lighter wallet and the ability to hear the turbo spool louder (if thats worth the $300 to you, then by all means go for it) but you wont see any performance gains or fuel economy gains.
Keep your, EGT's, boost levels and Exhaust Back Pressure levels in check and your Head gasket will treat you good.
2007 6.7 | EFI-Live | Draconian tuned TCM | T4 S366 | ARP | AFE | Fox | Carli
Old 08-22-2012, 06:09 AM
NWRQC's Avatar
Vehicle: 2007 RAM
Rep:80
Oh and you will love the way the truck drives once you delete it.
Old 08-22-2012, 07:07 AM
Rep:69
Like said above, I highly recommend the mini maxx as well. I also just zip tied my sensors and hard lines out of the way. The tuner will take care of any codes from not having the sensors plugged in.
