Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Brakes
Brakes Brake Maintenance and Replacement
Old 08-20-2012, 08:09 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
Default 09-12 rear rotors same as earlier?
Doing a search for rear rotors...just need to know if the Gen4 brakes are specific to those years or if they are carry overs from previous years.
Old 08-21-2012, 10:19 AM
moparornocar72's Avatar
Rep:630
I'm pretty sure they are gen4 specific. I know the fronts are for a fact so i'm assuming the rears are as well. Good luck!
14.268 @ 95 MPH Full Trim
Old 08-21-2012, 11:16 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Try looking up part numbers from an older model and newer to compare.
I'd GUESS that they are the same. Same axle and all, why would it change?
Sean
Old 03-28-2013, 06:25 PM
hemirae hemirae is offline
Vehicle: 2009 Dodge Ram
Trim Level: Laramie CC
Color: Black Crystal Pearl
hemirae is on a distinguished road
I have noted that after market replacement for rear rotors are larger in diameter than the front. Is this OK considering that the rear calipers are smaller as compared to the front?
Old 03-28-2013, 10:16 PM
I push the skinny pedal
Rep:3277
The rear rotors are about 1/2" larger in diameter than the fronts, the size of the caliper is just different since these trucks are front brake biased. I picked up the EBC pads and rotors for my '09, and they're showing the same parts number for all '09-'10 as the same ones for my '07, but not showing anything for the '11+ in the same rotor type, so I don't know if there's a difference in the later 4th gens or not, but I can't see there being one since the hubs and axles are the same.
Kurtis
Old 03-29-2013, 09:57 AM
snrusnak's Avatar
Rep:1385
Doesn't really matter(although it is odd). The size of the brake pad/caliper is what matters. You could have a rotor with a diameter of 10,000 feet and if you only put a pad/caliper on it that has a contact area of 8 square inches(say that's stock) then it will provide the same braking force as stock. Although it would cool significantly better/faster.
Sean
