Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 08-21-2012, 02:06 PM
Grizzly-Hemi's Avatar
Grizzly-Hemi Grizzly-Hemi is offline
Vehicle: 2012 Ram 1500 RCSB
Grizzly-Hemi is on a distinguished road
Default Going to grudge wars, few questions
Ok so this Saturday I'm going to the local track for grudge wars, my question is would it be safe to run 110 octane non leaded fuel in my truck, also with 17's and some weight reduction on that fuel on a cool night should I expect some et improvement?
Hoping to kill a few stangs, camaros, and a few diesels if any show up while I'm at it.
Thanks
14.61 @97mph 2.1 60ft all stock uncorrected, 3.55 LSD 18" Magnaflow
Soon to come: CAI and tuner
Old 08-22-2012, 02:09 PM
dodge man's Avatar
Vehicle: 2004 Quad Cab diesel
Rep:235
Unless your truck has a lot of mods, the race fuel is probably a waste of money. Your truck will only do so much timing advance and only has so much compression. Any octane above a certain number isn't doing much good. They say a stock Hemi will run good on 89 octane, but to make sure for racing I'd probably just run a 91 octane.
Old 08-22-2012, 03:52 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
If you run that high of octane you'll actually lose power. Like he said above, the hemi in stock programming is designed to run on 87, and run best on 89. I'd also put some 91 in it just to make sure you're getting everything you can out of it(just because it says 89 doesn't mean you're getting 89). Have fun and good luck!
Sean
Old 08-22-2012, 06:12 PM
hemiexp04 hemiexp04 is offline
Vehicle: 2014 blacktop qq 4wd 8speed
hemiexp04 is on a distinguished road
Run 93 octane (if avail). Try to have abt 1/4 tank of gas. Let the truck cool of for a while aprox 45 min. When u launch try not to brake stall a lot or any and just practice. Every truck is diff but for me my truck runs best when barley brake stalling to abt 1k rpms. Last time at track I ran 14.5 with same truck as you and heavy srt 22s so you should run abt the same
Old 08-22-2012, 07:11 PM
Thanks guys for the advice, Our premium here in ky is 93 octane I was just curious about the 110 because I can get it for $5 a gallon from a buddy who owns a race car supply store. Im just looking to get as close to 13's as I can (while Im still stock) and hopefully this spring I can get some 4.10 gears, stall converter, and a small shot of nitrous and break into the low 13's maybe high 12's depending on how much juice I run.
Old 08-22-2012, 08:46 PM
You'll easily be in the 12s with those mods. I ran a 13.3 @ 96 mph with a 2.0 60ft with a 75 hp dry shot, flowmaster muffler, sonnax line booster, and a 180* thermostat. I have 3.55 gears too and it was hot outside.
Old 08-23-2012, 06:42 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
looking forward to your results...
Old 09-03-2012, 06:15 AM
Sorry it took so long for me to post my results but ran 4 runs@ 45min intervals, first run was a 14.87 @95 (didn't hook) second was 14.53 @98 (best of the night) a camaro smacked the wall in between my second and third run and screwed up the clocks, last two runs were 15.55 @88 and 15.31@ 91 according to my time slip. But got some great kills, they include a 07 ram 2500 cummins with a tuner and exhaust, gmc rcsb 1500 with 5.3 tuned gears and mild cam, 2012 ram rcsb express hemi 4x4, and a 2002 mustang gt full bolt on, gears, camed, sct 93 octane tune and drag radials (sleeping at the tree) so overall a very good weekend. 17" wheels and some weight management and picked up almost three tenths over my best run last time at the track.
Old 09-03-2012, 11:55 AM
moparornocar72's Avatar
Rep:630
Nice kills, How were u launching, what gear and did u have tow/haul turned off?
14.268 @ 95 MPH Full Trim
Old 09-06-2012, 11:11 PM
I was launching at 1000-1500rpm, I was using manual mode on the shifter only using 1st 2nd and 3rd (second prime) with traction control off, at the finish was running 5500-5700rpm in second prime which got be better results than shifting to fourth
