Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 08-21-2012, 09:21 PM
2000RAM's Avatar
2000RAM 2000RAM is offline
Vehicle: 2000 Dodge Ram 1500
Trim Level: sport
Color: yellow
2000RAM is on a distinguished road
Default adding more lift
Hey everyone I have a couple questions about adding more lift to my truck. So right now I Have a 5.5" fabtech lift and sitting on 35's. I want to add 3 more inches by putting a 3" coil spacer and then level out the rear. My questions are, if I add the spacer will it mess with my driveshaft, will it stuff my front tire into the bottom fender corner near the door, and will I need to get a drop pitman arm? Another question is, is the truck sits level now so couldn't I Just put 3" up front and 3 in the back and sit level still? ANd also how big of tires can I run being at 8.5" of lift?.
Old 08-23-2012, 12:32 AM
PARam5.9 PARam5.9 is offline
Vehicle: 98 Dodge Ram 5.9
Color: Emerald Green
PARam5.9 is on a distinguished road
Others might be able to chime in who have done this sort of lift before, but you will need a drop pitman arm and probably new driveshafts. You should be able to run 36s if not 37" tires. I'm assuming you have a double steering stabilizer. If not, you will need a double stabilizer kit. I don't see why you shouldn't be able to just add 3" in the front and 3" in the rear if you already have the truck leveled out.
Old 08-24-2012, 08:07 AM
2000RAM's Avatar
Trim Level: sport
Color: yellow
Im not sure if the fabtech lift came with a drop ptiman arm or not. Looks like right now I can clear 36's. I wonder if i can clear 38.5s but Ik i need gears
