Old 08-23-2012, 06:17 AM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:912
i dont bleieve this light gasket is only a 2010 issue.
back when i owned a 96 ram, i had water on the front passenger floor board for over a year...couldnt figureit out until i read snrusnak's post he copied above. after the fix, no more water in the floor board.
Old 08-23-2012, 10:07 AM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Originally Posted by primo spaghetti View Post
someone please correct me if im wrong, but the other lights in the third assembly are ot reverse lamps...they are cargo lamps...try the switch below your headlight dial...that should turn them on.
the last itme i changed my bulb, it was shattered, and i too thought water penetration even though there was no sign of it.
but for the first time this week, ive had water on my headliner after washing the truck...the third brake light seal is notorious for water.
since i went to teh LED bulbs though, i havent had any issue with the bulbs breaking/burning out.
Yes sir - I made a misstep there when I was posting - they are only cargo lights/and come on when you hit the fob. I was so focused on testing all my lights that I got confused there for a moment.
At any rate, I changed the bulb again and all is well. I can't see any signs of water infiltration in the housing, so I guess I'll just buy extra bulbs and keep changing them out every 20k miles.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 08-23-2012, 02:20 PM
dkerr24 dkerr24 is offline
Vehicle: 2011 Dodge Ram
Color: Dk Cherry Red
Rep:14
dkerr24 is on a distinguished road
Why are you guys putting in regular bulbs in the 3rd brake light? Why not just put in a Putco LED light? It will last the life of the truck. Put one in mine, never mess with it again. Did the same with the 2 cargo lamps in the housing as well.
Darin
Old 08-23-2012, 02:36 PM
moparornocar72's Avatar
Rep:630
I would make sure it is sealed properly (moisture can still get in) and use "bulb grease" to keep corrosion and pro-long the life of the bulb. hope this helps! good luck!
14.268 @ 95 MPH Full Trim
Old 08-24-2012, 10:40 AM
70x7's Avatar
70x7 70x7 is offline
Vehicle: 2008 QC HEMI
Rep:34
70x7 is on a distinguished road
Originally Posted by Turbovsix View Post
Not in any vehicle I've ever owned
..I was talking about the changing of underwear
2008 1500 QC HEMI--
Spectre Intake*Flopro Max Muffler*Superchips Cortex*Bilstien 5100*Pioneer AVH-X7500BT*Magnaflow Ypipe*Viper Alarm*85mm Throttle Body
Old 08-27-2012, 09:37 PM
Mattones's Avatar
Mattones Mattones is offline
Vehicle: 2009 Dodge Ram 1500 SLT Quad
Rep:164
Mattones has a spectacular aura aboutMattones has a spectacular aura about
Summer of 11 i repalced one tail lamp and this summer i had to replace the 3rd break light.
2009 Dodge Ram 1500 4x4 5.7 Hemi Quad Cab
Cat Back Magnaflow Exhaust stainless, Tinted Front Windows, Painted Engine Cover, Red Calipers, LED Reverse Lights, Lightbar and 4 Hella 500
Old 09-01-2012, 01:27 PM
lirex3 lirex3 is offline
lirex3 is on a distinguished road
Funny... I have seen a lot of ram trucks with the third light not working. Mine is fine but only have 18k on the truck.
