Old 08-22-2012, 07:58 PM
BudTheGrey BudTheGrey is offline
Vehicle: 2012 Dodge Ram
Trim Level: Tradesman
BudTheGrey is on a distinguished road
Default "Light Electric" or "Heavy Electric" ?
So, in the setup for my factory integrated trailer brake, I can choose "light electric" or "heavy electric". I can't find any documentation that tells me the difference.
I have a dual axle equipment trailer, brakes on both axles. The trailer weighs about 1200 lbs, and is rated for 7000 lb gross. Payload is usually between 2500 and 4000lbs
Old 08-22-2012, 09:22 PM
TRCM's Avatar
TRCM TRCM is offline
Vehicle: 2012 Ram Laramie 4x4 CC
Color: White w/silver trim
Rep:63
TRCM will become famous soon enough
Personally, if it is less than 50% of the max towing cap, I'd use light. More than 50%, I'd use heavy.
You can also try both, and see how the trailer brakes work.
I will probably use heavy when I tow my camper, since it weighs ~ 6000 lbs.
1996 Cherokee Sport 4x4
1988 Cherokee Pioneer 4x4
Old 08-24-2012, 01:16 PM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Ram 1500
Trim Level: Express 4X4
Rep:358
I'm betting if you switch to "heavy" it won't recognize the electric on your trailer. It didn't mine anyways when I had the same question. "It's light".
333Half the beast
I used to be
Old 08-24-2012, 04:00 PM
Dragonmaster13 Dragonmaster13 is offline
Vehicle: 2012 Ram 1500 SXT Crew Cab
Rep:14
Dragonmaster13 is on a distinguished road
Heavy = 3 braked axles or more
Light = 2 axles and less.
