Old 08-22-2012, 08:09 PM
TravRam07's Avatar
TravRam07 TravRam07 is offline
Vehicle: 2007 Dodge Ram 1500 QC HEMI
TravRam07 is on a distinguished road
Default Manifold Bolts break when trying to add new headers
Hello,
Looking for some help/ insight. Took my truck to have some new shorty headers put on and the auto shop called me because they snapped the first bolt off when trying to take the nut off that holds the heat shield on. They were afraid to go any further with the project because they said they will probably all break off. What can I do? I have my headers and desperately want them to be put on the truck...Could possibly do it myself, but it looks like a helluva job... any insight on getting these out safely would be great. Would really like to get this done sooner than later.
I have an 07 hemi QC 4x4...just for your consideration with tips/ tricks. I mean, the truck isn't that old. Should these be that stuck on there? does engine heat affect it that much? Thanks in advance. I know it shouldn't be too difficult, guys are putting headers on trucks left and right...especially to ones older than mine. ahhh!!
Old 08-22-2012, 08:21 PM
moparornocar72's Avatar
Rep:630
Seems as though a good lot of bolts touching the exhaust system break over time, Depending on which bolt it is, it is probably leaking, I would have them go ahead and take them off, if they break, install new bolts/nuts and get it over with. Just my opinon! Good luck!
14.268 @ 95 MPH Full Trim
Old 08-22-2012, 08:41 PM
I push the skinny pedal
Rep:3277
Have them continue to remove the bolts, you may break a few, but I never recommend reusing header bolts just because of the heat cycling that they go through. You can get a good set of stage 8 locking bolts or get a set of OEM replacements. To prevent seizing and snapping you can have them use high-temp anti-seize on the new ones going in.
Kurtis
Old 08-22-2012, 09:38 PM
Red05Ram Red05Ram is offline
Vehicle: 2005 Dodge Ram 4x4
Color: RED<----
Rep:15
Red05Ram is on a distinguished road
When I had my long tubes done 5 bolts broke off! Sucks guess it's half common
K&N FIPK,Diablo Custom tune,TTI Long Tubes,True Dual 2 1/2 inch, Borla XR1 Mufflers,4.56 gears,Jet 180 stat, Fastman TB, Cam Swap
Old 08-22-2012, 09:42 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
x2. get it over with. order some some stage 8s with anti-seize and you're golden.
Old 08-22-2012, 10:51 PM
UNBROKEN's Avatar
UNBROKEN UNBROKEN is offline
Vehicle: 2012 Ram R/T
Trim Level: R/T
Rep:123
UNBROKEN will become famous soon enoughUNBROKEN will become famous soon enough
I never change a set of old manifolds without soaking all the bolts with penetrating oil for at least a day. Not WD-40....penetrating oil.
Old 08-23-2012, 08:56 AM
TravRam07's Avatar
You guys talk about breaking bolts and replacing them as if it were a non-issue...The auto shop was telling me if they snap more "interior" bolts they would have to remove the cylinder heads to replace them?.?.? Thus making my cost rise from about $165 to $1200-$1500...INSANE!! Just for some headers.
I have a different set of bolts that came with the headers that are going in. Should I buy the stage 8 ones you are all talking about from Jegs?
Is this a job that I should be able to tackle myself? I can work a wrench, but not a mechanic by any means...Been trying to look up tips and tricks to installation and there just isn't a whole lot out there.
Thanks again for any and all help!!
Old 08-23-2012, 12:31 PM
nick.gauv's Avatar
nick.gauv nick.gauv is offline
Vehicle: 2006 dodge ram 1500 hemi
nick.gauv is on a distinguished road
I think what the shop is concerned about is drilling out those broken stud pieces out of your heads after they have broken of! It really is a awkwarg place to work
Old 08-23-2012, 02:03 PM
Rep:630
removing the heads would be a worse case scenario, they told u that just so u are aware, I am mechanic and have to drill out bolts often because others do crappy work or they simply break, it's not that big of a deal really, definitely more work but nothing that can't be fixed. good luck!
Old 08-23-2012, 02:24 PM
age525's Avatar
age525 age525 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:91
age525 will become famous soon enough
I recently went through the same thing putting on my American Racing Headers. Before I even started one of the heat shield bolts were broken off into the head. Everyone I asked said to just leave it alone but there was no way that I could leave it like that. I went on to soak all the other bolts and then one by one heat them with a torch and slowly pull them out. its took me a week to get them out just working in my spare time. I managed to not break any other bolts. once the headers were off I drilled into the broken bolt and used and easy out to pull the broken portion from the head.
In the end...it was worth it for me.
S&B Cold Air Intake, American Racing Headers, DB Performance Cat Back Exhaust, Recon LED Taillights, Bilstein 5100's, Toyo Open Country AT 2, Diablosport Predator, Recon Line of Fire, JL Audio 10W3 StealthBox, Alpine iDA-X305s Head Unit, Detroit TrueTrac
aftermarket headers, exhaust, header installation, manifold bolts, manifolds
