Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-23-2012, 01:57 AM
Mugzy2001 Mugzy2001 is offline
Vehicle: 2001 Dodge Ram 1500
Color: blue
Mugzy2001 is on a distinguished road
Default A/C works on high
I have a 2001 Ram 1500 5.2. A/C will only work on high. Can anyone tell me if this a switch, motor or resistor problem. Thanks
Old 08-23-2012, 02:03 AM
Ram11's Avatar
Ram11 Ram11 is offline
Now 2012
Vehicle: 2012 Dodge Ram 1500
Color: Deep Red Pearl
Rep:146
Ram11 will become famous soon enoughRam11 will become famous soon enough
Tuff without seeing first hand,,,,resistor or switch...the motor works right,,,
Factory Fender Flare's... Smoked Rain Guard's... 8,000 Hid'... Zeta Body Side Molding... Painted Pinstripe... Dodge S/S Door Sills... S10 Bed Slide... Ghost Flames... Mopar Tonneau Cover... Mopar High Performance Exhaust... K and N Cold Air Intake...Bilstein 4600 Front Shocks.....Thunder Form enclosure Loaded with 2 10 Kenwood Subs,,
Old 08-23-2012, 03:51 PM
ramfam's Avatar
ramfam ramfam is offline
Vehicle: 2001 1500/1982 D150
Trim Level: Base
Rep:21
Id go resistor only cause high speed is the only one that usualy dsnt go through windings or capaitors to slow power output. Its usualy on its own so fan motor has full power. Also don't be surprised if plug might have melted on some of lower speeds from heat generated by the resistor its self. My dakota did that it sucked.
Old 08-24-2012, 12:25 AM
Color: blue
Yup the motor works. l'll check the resistor. Thanks
Old 08-24-2012, 12:27 AM
Color: blue
Thanks. Is the resistor located on the left side of the glove box?
Old 08-24-2012, 11:34 PM
ramfam's Avatar
Trim Level: Base
Rep:21
Yes close to trans hump should be a little metel box with a harness plug.
Old 08-26-2012, 11:53 AM
Color: blue
Thanks, I'm looking into it today.
Old 09-01-2012, 01:52 PM
Color: blue
Thanks for the help. Picked up the resistor for 49.99 and replaced it in less than five mins. I'm thinking a shop would have gone with all the BS and charged me 200.00 to 300.00.
