Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion > Nitrous Discussion
Nitrous Discussion Questions and Answers regarding adding Nitrous Oxide to your Dodge Ram.
Old 08-23-2012, 04:56 AM
Jayzsun's Avatar
Jayzsun Jayzsun is offline
Vehicle: 2012 Dodge Ram crew cab.
Trim Level: st
Jayzsun is on a distinguished road
Default TPS resistor wire
Hi!Anyone know where to hook up the ZEX tps resistor wire?What color is the voltage wire from the tps on a 2012 5.7 hemi crew cab?Thanks.
She thinks my Dodge is sexy!
Old 08-23-2012, 08:59 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
Why do you want to put a resistor on the TPS? I would think this would REALLY F up the signal and make the truck undriveable...since it's fly by wire.
Sean
Old 08-23-2012, 11:48 AM
Jayzsun's Avatar
Trim Level: st
It is actually a drive by wire throtlle body and the ZEX wet nitrous kit for hemi 5.7L 2012 include the tps resistor wire to hook it up with the nitrous/fuel module...
Old 08-23-2012, 11:56 AM
snrusnak's Avatar
Rep:1385
Oh I don't know what it does then, not real familiar with nitrous...
Sean
Old 08-23-2012, 02:03 PM
Jayzsun's Avatar
Trim Level: st
No problem,just trying to give me some help hey?
Old 08-23-2012, 02:31 PM
snrusnak's Avatar
Rep:1385
Yeah I just don't understand why you'd want anything to tap into the tps signal? Maybe the nitrous kit is activated by the tps signal? So it knows how much to inject?
Sean
Old 08-23-2012, 06:12 PM
Jayzsun's Avatar
Trim Level: st
This is because the nitrous controler needs to know when the throttle body is at WOT....by reading a voltage signal by the resistor wire.
Old 05-02-2013, 06:05 AM
Steermaster's Avatar
Steermaster Steermaster is offline
Vehicle: 2004 Dodge Ram
Color: Orange
Steermaster is on a distinguished road
Send a message via AIM to Steermaster
If you contact ZEX they will give you troubleshooting over the phone, as well as check their site, the install PDF they have for each piece is pretty spot on. Good Luck! I will be oding my install later this month so please do post back what you ended up doing
Old 09-01-2014, 05:42 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
Bump you figure it out?
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 09-19-2014, 01:15 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
I tapped the second wire on the pedal sensor for tps from the zex nmu... not sure if it's the same for the 4th gens..
-fast freddie- one quick 05 hemi qc...with over 275k miles on odo... on the 5.7, stoker 6.4 now...Inertia Motorsports 392 stroker
