Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > Dodge Ram Detailing and General Maintenance Forum > Oil Change
Oil Change Ready to change the oil in your Dodge Ram? Engine -Trans - Differential - Transfer Case
Old 08-24-2012, 11:19 PM
EFIsuicide EFIsuicide is offline
Vehicle: 2012 Ram
EFIsuicide is on a distinguished road
My second oil change I switched to Mobil 1 5W-20. Costco had a instant rebate that knocked it down to $26.99 a 6 quart case. My hybrid only takes 4.5 quarts and the hemi takes 7, so it works out to just under 2 cases when I change them.
Old 08-25-2012, 04:07 PM
nickxc nickxc is offline
Vehicle: 2012 RAM 1500 LARAMIE
Color: Mineral Gray Metallic
nickxc is on a distinguished road
Never heard of a catch can... interesting...
Old 08-26-2012, 12:16 AM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
Any oil you can prevent from going into the intake air system is a good thing.
A "gasoline" engine is supposed to run/burn on gasoline/ethanol not oil vapor.
Oil vapor becomes oil puddles in intake and burn't crud on intake valves, intake ports and tops of pistons. Really bad things happen when top rings seize or pieces of burn't crud come off the top of pistons and rattle around, let alone the detonation that happens because of oil mixing with the gas/air mixture.
oldhp
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 08-26-2012, 01:12 AM
Went with 100% synthetic at 5,000 kms and never looked back. The Amsoil 0W20 that I am using has been an excellent oil and I have no regrets. I have also installed a catch can from BT and, like everyone else has posted, it is catching alot of oil that would have gone into my intake. Definitely a mod worth doing.
I too made the switch to synthetic on my first oil change.
My next one in 1k will be using Amsoil 0W20 (thanks Randy)
I found the truck drove better using synthetic oil. Maybe just me but
I too have a catch can and in 4k of mileage I had half a can (catch can) full of oil
Old 08-28-2012, 01:30 PM
jgos929 jgos929 is offline
Vehicle: 2012 Dodge Ram
Trim Level: SLT Lone Star
Color: Sagebrush
Rep:-5
jgos929 has a little shameless behaviour in the past
Originally Posted by LeftCoast View Post
I think that oil going down the intake is not needed. I'm getting a catch can.
The get you one hot rod!!!!!!! Post up some pics of it when you get it installed. I always like to see what mods people are doing.
oldhp
Yet millions of automobiles without catch cans have gone billions of miles with none of the above adverse reactions. How does one explain that?
The science behind a catch can makes perfect sense and in reality is probably even a good thing to have. BUT...... there is no evidence that supports an automobile with a catch can will out live one without.
Old 08-29-2012, 12:00 PM
rdsabin rdsabin is offline
Vehicle: 2012 Sport Reg Cab 4x4
Trim Level: Sport Reg Cab
Rep:186
rdsabin has a spectacular aura aboutrdsabin has a spectacular aura about
True you don't need a catchcan but that being said, if you don't have it you will be cleaning or paying someone to clean your throttle body due to it being covered in sludge from all the oil being dumped in the system from the PVC valve. I prefer preventative maintenance and have a Catchcan on my Super Bee and I just traded off my 10 Ram that had the Catchcan. I currently am waiting for a new one for the 12 Sport I purchased. I prefer to get the clear bottoms so I can see how much oil is in them versus the billet bottoms. I also use BT Catchcans.
2012 DodgeRam 1500 4x4, 20% Tint, Running Boards, Class IV Hitch, 14" Win Muffler, Catch-Can, Tow-Hooks, LED Tailgate Bar
2008 Dodge Supe Bee, Catch Can, Backup Camera, 20% Tint all windows, CAI, AFE Filter
Old 08-29-2012, 12:46 PM
Rep:2657
BT & Speed Logix are the same catch can
spark plugs can NOT produce enough heat to lite off oil
without a catch can, you will either be using a lot of SEA FOAM or taking your vehicle in for a fuel system cleaning
Fouled plugs, & throttle bodies & lowered MPG are common on vehicles with SMOG systems
The catch can helps to keep the combustion system oil free
Before SMOG systems, all engines had road draft tubes, oil pressure that builds up inside the engine, along with oil vapor, dumped directly on the road through the road draft tube. That is why the 1960s & before engines lasted so long, many are still running
http://img560.imageshack.us/img560/4503/img0494j.jpg
this image was taken after a 7600 mile road trip, it is almost 2/3rds full
Old 08-29-2012, 08:19 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
There are oil drain holes in the cyl. head to let the oil drain back into the crank case. The oil that the catch can accumulates is not necessarily being burnt. The oil is helping lubricate the top end of the engine. I just do not see the purpose of installing something that removes oil from my engine's vital components, especially on a D.D.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
Old 08-29-2012, 08:57 PM
Im close to that in mileage and have yet to check mine....I better do so tomorrow
Old 09-02-2012, 01:19 AM
oldhp's Avatar
Color: WHITE
Rep:902
jgos929, Yes engines will continue to run but not as new. My friend runs a shop, the first thing done, before a tuneup, is run SeaFoam thur engine. The sniffer in the tailpipe doesn't lie, big difference in emissions with just that. As engine ages more crud on top of pistons, ring landings ect cut down performance.
Over time you lose performance, but you don't feel it.
Thats why I'm a huge believer in the cleanest combustion chamber you can get will keep engine running stronger, longer.
So any oil I can keep out of CC the better.
oldhp
How would you know?
