need help with idle and MAP sensor - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-23-2012, 09:16 PM
fred9776 fred9776 is offline
Vehicle: 1997 Dodge Ram 1500
Trim Level: Slt-Quad Cab
Color: Black-Red
fred9776 is on a distinguished road
Default need help with idle and MAP sensor
Hi guys,I have a 97 1500 w/5.9 gas.When i start it in th AM I have no problems with the idle.When i go somewhere and shut it off and restart it,it will run fine for about a miniute,then the iac vale opens up and almost stalls.Now what I did... I changed the IAC valve,same problem,so I bought a new map sensor,same thing.Took a volt meter to the MAP sensor,getting 5 volts to it,went to middle wire getting when on idle around 1.35ish to 1.40.Now when i let it idle,after around a min or so,the voltage starts to creep up and continues to about 4 volts and almost stalls and sometimes it does.When it doesnt stall,it will run really rich then start to creep back down to 1.30 to 1.40 and will idle till it runs out of gas or I shut it off.then if I shut it off and re start it,it will do it all over again.Drives fine,if i take off before it does it like down the road a bit,it will be fine.Now where do I go????
Old 08-24-2012, 08:23 AM
kenstauss kenstauss is offline
Vehicle: 2010 Ram 1500 BH
Color: Gold
kenstauss is on a distinguished road
Have you tested the voltages on the iac valve?
2005 Ram 1500 Quad Cab 4.7L Magnum
makes me feel like a kid again!!!
Old 08-24-2012, 12:43 PM
Color: Black-Red
no i havent.I figure if its going in and out withe the variation of the Map sensor it should be ok, Once the voltage on map comes back down it closes up, plus i wouldnt know what the voltage should be.I also changed the computer and the ambiant sensor behind the altenator its the same thing.Also just went out and looked down the throttle body and no oil on the bottom.what else controls the iac besides the map sensor?
Old 08-25-2012, 10:03 AM
Color: Gold
sorry. I mis-spoke when i said the iac...check the voltages on the tps sensor. i'm having a similar problem as you and that was the first thing i was told to check. Mine has erratic idle behavior. it will start and idle high (around 1300) then drop to around 600. and cycle between those two for a few minutes. I took the map sensor out 2 days ago and cleaned it out. Ran like new until last night and started with the weird idle thing this time after a few cycles it went low and died. Started it back up and it runs fine until i put it in park again. Try the tps sensor voltages. As the throttle opens the voltage should drop steady....if it's erratic...replace the tps.
Old 08-25-2012, 10:07 PM
Color: Black-Red
Ok.I went to a friend of mine on the next block,i feel bad though cause i dont really see him unless i have a freekin problem, but he worked on dodges for 25 yrs at a dealer and he said that could be 3 problems..first we were checking it quickly and he said that the 360's are notorious for intake manifold gaskets to create a very small vac leak witch the computer tries to compinsate for it.2nd,he was checking my radiator and said it is clogged that the upper hose was hot and the lower one was cool but i guess I have enough flow because it don't overheat.He said the bottom one should almost be very warm and it wasn't.he said that could throw off the comp and again try to compinsate on the idle.Bull S..t right???Then he wanted to know if the 5.9 had a 2nd coolant temp sensor,which i told him i didn't know and i would check the hays manual.the sob was right! There is 2 of them,1 is right behind the alt on the intake down on the bottom and that one is for the inst panel gauge and the 2nd is right by the output radiator hose on the intake,its a 2 wire that goes to the comp.So what he told me is to change the radiator first,and if I still had the idle issue,check that 2nd sensor on the right according to him I need the radiator anyway so do that which is a little easier than pulling the intake,and if it still does it check the sensor. I bought a radiator on ebay w/a lifetime warranty for 93 bucks so ill get back 2 u in a few days.and if u need any parts I go to rock auto.com.Their sooo much cheaper than everybody else..Later, fred
Old 08-27-2012, 10:49 AM
Color: Gold
keep me posted...
Old 09-04-2012, 09:02 PM
Color: Black-Red
ok no change.My guy is going to talk to his dodge guys and see what they say
Old 09-05-2012, 07:47 AM
Color: Gold
bummer. I finally broke down and replaced the map sensor and it seemed to work fine for a while (again) and then out of the blue started doing it again. I think I'm going to hit up scottykilmer.com and see what he thinks.
