1994 ram 1500 5.2 too much cam for stock ECM - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8
Old 08-23-2012, 10:01 PM
spearchamp1g spearchamp1g is offline
Vehicle: 1994 Ram 1500
spearchamp1g is on a distinguished road
Default 1994 ram 1500 5.2 too much cam for stock ECM
Hello mopar friends. I started out with a 1994 ram 5.2 so a few weeks ago I blew a driver head gasket. The truck has 200,000+ miles. So I decided to pull the motor an fresh in it up. I get te heads to the machine shop. They magna fluxes both heads. It had a crack between both valves on #1,7 an #2,8. So I bought new heads. Supposed to be beefy in the spots that had cracked. So I decided to go ahead an rebuild. So I had it bored .040 over an new everything. Bought a BIG cam .512 intake an .520 exhaust. With 208 & 214 duration. Roller cam. Everything new except block, intake, ECM, and crankshaft. So now my stock computer is bogging down my motor. What do I need to do to fix the problem. I'm $3000 in so far. Please help
Old 08-23-2012, 10:31 PM
moparornocar72's Avatar
Rep:630
You need to have someone tune the ecm to match your current setup. Most people will write tunes for a few hundred dollars! good luck!
14.268 @ 95 MPH Full Trim
Old 08-24-2012, 02:31 PM
Gen1dak Gen1dak is offline
Vehicle: 1990 RamCharger
Rep:99
Definitely need that aftermarket ECM re-tune. A side note, that stock intake runs outta steam around 4,000rpm, cam peaks near 6k.
Old 08-25-2012, 02:11 PM
HemiLonestar's Avatar
Rep:300
HemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the roughHemiLonestar is a jewel in the rough
Kind of a big cam to put in a small displacement engine in a big truck.
"Big Red"
2003 Ram 1500 QC Hemi Lonestar "Big Red"
2006 Charger R/T "Little Red", 2005 Magnum R/T
(Mods list in profile)
Old 08-25-2012, 07:19 PM
Rep:99
Agreed. Without a gear swap and a high stall converter that things gonna be a pig off the line no matter what programming you get. And with the stock intake it'll suffocate at higher revs.
