glasspack - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 08-24-2012, 08:07 PM
5.91500 5.91500 is offline
Vehicle: 1999 Dodge Ram 1500 5.9LV8 4WD
Trim Level: ST Quad Cab
5.91500 is on a distinguished road
Default glasspack
which direction do i install my glasspack muffler
Old 08-25-2012, 09:24 AM
ArtNJr ArtNJr is offline
Vehicle: 1998.5 Dodge 2500HD 4x4
Trim Level: SLT Laramie
Engine: 1998-1998 359ci (5.9L) Cummins ISB 24-valve Diesel I6 235hp 420lb/ft (manual), 215hp 420lb/ft(auto)
Rep:57
ArtNJr will become famous soon enough
It shouldn't matter unless the inside tube is louvered -- the one I have is just perforated steel. If the core is louvered, install so the open side of the louvers faces away from the engine.
"One of the problems with 'majority rule' is the majority is usually wrong." -- Thomas Jefferson
Old 08-30-2012, 07:38 AM
Nck's Avatar
Nck Nck is offline
Vehicle: 2nd Gen 2002 RAM 2500 24V
Trim Level: Laramie SLT
Color: Light brown/Goldish
Rep:74
Nck will become famous soon enough
Why do a glass pack? Forget the muffler, and put pipe in it place.
But leave the stock Cat. You will never find a better sound, and so so so much better than a glass pack, and louder.
Old 08-30-2012, 08:53 AM
Rep:57
Louder, yes, but I disagree with "better". I ran my (Cummins diesel) truck which did not come from the factory with a Cat for a little while with only the pipe coming from the turbo (ends under the passenger's seat) & surprisingly, with the glasspack on it's almost as loud.
BUT -- there's a "raspy" sound with no muffler that I find very annoying & at certain rpms there's a "drone" that'll drive you nuts. The glasspack tones all that down & what you hear is a "pleasant" loud -- the raspy sound is gone & so is the drone @ sustained highway speeds -- now the engine sounds like the old nickname,"Hummin' Cummins" & I can still listen to the radio! And while a Cat converter acts like a muffler in some respects, it doesn't get rid of the "obnoxious loud" sounds.
The glasspack I got (same inside diameter as the pipe from the turbo) does not restrict exhaust flow @ all & I've made similar exhaust systems for gasoline engines too (for 40 years), getting the same results -- nice (loud) tone, but not obnoxious.
