Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 08-25-2012, 11:27 AM
Kevin's Avatar
Kevin Kevin is offline
Vehicle: 2006
Color: Red grey
Kevin is on a distinguished road
Default 2006 quad cab noise under pass side getting worse
I've been having this problem for a couple years now, I've checked everything under the truck but cant pinpoint the sound, It sounds like the body is loose from the frame, I'm sure it isn't (just a description of the sound ) It at first only happened when there was a passenger in the pass side and you hit bumps, now its constant and even worse when you hit bumps the truck has 102,000 miles and started approx when it had 90,000 mi. I just changed the stabilizer bushings which were pretty worn, but the stabilizer links are tight. Any ideas would be helpful Thanks Kevin
Old 08-25-2012, 11:31 AM
Kevin's Avatar
Vehicle: 2006
Color: Red grey
Default oops sorry just realized im in the 1st gen forum
sorry, in too much of a rush clicked the wrong forum
