Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 08-25-2012, 10:34 AM
Kevin's Avatar
Kevin Kevin is offline
Vehicle: 2006
Color: Red grey
Kevin is on a distinguished road
Default 2006 quad cab noise under pass side getting worse
I've been having this problem for a couple years now, I've checked everything under the truck but cant pinpoint the sound, It sounds like the body is loose from the frame, I'm sure it isn't (just a description of the sound ) It at first only happened when there was a passenger in the pass side and you hit bumps, now its constant and even worse when you hit bumps the truck has 102,000 miles and started approx when it had 90,000 mi. I just changed the stabilizer bushings which were pretty worn, but the stabilizer links are tight. Any ideas would be helpful Thanks Kevin
Old 09-03-2012, 10:50 PM
Chunkem's Avatar
Chunkem Chunkem is offline
"Just living the dream"
Trim Level: Longhorn Rambox
Rep:1637
Please keep us updated and let us know how you make out......
Old 09-05-2012, 01:23 PM
HemiBeast HemiBeast is offline
Vehicle: 2003 Dodge Ram Hemi
HemiBeast is on a distinguished road
You could possibly check the body mounts. Sometimes the bolts will be tight but the rubber can degrade and loosen it's "grip" in the body. As a matter of fact, Chevy even has a TSB on the body mounts on Silverados/Sierras Making the same noise, their solution is to install a shim kit.........My advice would be to actually replace any failing mount instead of taking this slightly cheaper route. Of course step one would be to put a socket on the bolts, if loose tighten them and go drive it, hopefully this helps. BTW, the spec for the body to frame bolts is 60 ft-lbs.
