Old 08-25-2012, 11:46 AM
ridinhigh ridinhigh is offline
Vehicle: 2006 Dodge Ram 1500
Color: silver
ridinhigh is on a distinguished road
Default 06 4.7 dodge ram will not start at all
2006 dodge ram will not start the other day i went outside to leave turned the key and all i hear is a single click, we gave it a jump start and it finally turned on, so i figured the battery was bad so i replaced it and now it wont start at all just clicks , and i bench tested the starter and it passed 3 times , idk what it could be need help????
Old 08-25-2012, 12:08 PM
Color: silver
i can hear the fuel pump turn on so its not that either anyone ever solve this problem?
Old 08-25-2012, 06:00 PM
SuperiorStyles's Avatar
SuperiorStyles SuperiorStyles is offline
Vehicle: 2002 Dodge RAM 4.8L 290ci
Trim Level: Quad Cab SLT
Rep:12
SuperiorStyles is on a distinguished road
Send a message via AIM to SuperiorStyles Send a message via Yahoo to SuperiorStyles
You might first wanna run through the Relay and fuses make sure all your fuses and relay are working . 2nd go to the starter motor and check if your ignition key is sending signal to the starter to engage the solenoid. Start off with those two just to save you time and money before you go spending on a mechanic.
Old 08-31-2012, 12:45 AM
goatman65's Avatar
goatman65 goatman65 is offline
Vehicle: 2009 Ram 4X4
goatman65 is on a distinguished road
clean the ground returns.. including the grounding straps at the rear of the heads.. the other end being near the top of the firewall..
goatman
