Old 08-27-2012, 12:12 AM
redfox redfox is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: sxt
Color: dark gray
redfox is on a distinguished road
Default What the best spark plugs to run???
I have a 2008 ram 1500 5.7L. i wanna do my plugs and not sure which ones to use any insite? what do you think about the G3 plugs??
Old 08-27-2012, 12:26 AM
TheSatinPumpkin's Avatar
Vehicle: 2004 Dodge Ram
Color: Satin Orange
Rep:605
Oem champion plugs
Old 08-27-2012, 07:32 AM
Striker Striker is offline
Vehicle: 2013 RAM 1500
Trim Level: Outdoorsman
Color: Black on Grey
Striker is on a distinguished road
On this note, dealer tells me it's $500 to change the spark plugs on my '08 HEMI. Says the brake booster has to come off and all that. Is this true. I'm a mechanic, and I instinctively second guess what the dealer tells me as far as labor time and cost. I have heard that some people have done it themselves, and was just wondering if it really was this much trouble, or if it could be done yourself in the backyard. I realize there are 2 spark plugs per cylinder, but the dealer also told me the plugs were $16 each. This seems a bit ridiculous to me when most places I have read say that the OEM plugs are just basic Champions. Any help is much appreciated. Thanks.
Old 08-27-2012, 11:12 AM
bucks bucks is offline
Vehicle: 2004 Dodge Ram 1500
Rep:17
bucks is on a distinguished road
With a few hours and some patience they're not too bad to do, the ones at the back by the brake booster are a pain but no need to pull the booster off.
2004 Dodge Ram 1500 Hemi Sport, AWD, Muffler delete
Old 08-27-2012, 02:02 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
I can't find anything in the service manual (installation or removal) that says the brake booster has to come out. Others have reported that a good assortment of extensions, swivels and some patience and you can do it yourself in a couple hours.
Old 08-27-2012, 02:18 PM
Rep:2657
the Gen 4 Rams spark plug 5.7L recommendations are
Champion REC14MCC4
NGK LZFR5C11
NGK V-power spark plug 92174 LZFR5C-11 $4.57
V-Power Plug, 14mm Thread Size, 26.5mm (1.04") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Extra Projected Tip, Solid Terminal Nut, V-Power (V-Grooved Center Electrode), .043" (1.1mm) Gap, Heat Range 5
Make: CHRYSLER
Model: 300 - C
Year: 2009
Engine: V8 - 5.7L - EZD
Iridium plugs are not recommended
Old 08-27-2012, 05:46 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
NGK's if you are performance minded (5306's)
Old 08-28-2012, 07:36 PM
VIPDHEMI's Avatar
VIPDHEMI VIPDHEMI is offline
Vehicle: 2010 Dodge Ram R/T
Trim Level: R/T
VIPDHEMI is on a distinguished road
Champion REC14MCC4
NGK LZFR5C11
Make: CHRYSLER
Model: 300 - C
Year: 2009
I thought the Iradiums were ok but platinum plugs were no good?
ARH Headers,AirRaid CAI,ported TB,DSP 93 tune,BT catch can,2/4drop,tint,14"maggy,resy's removed
Old 08-29-2012, 01:43 AM
JoshikusIII's Avatar
JoshikusIII JoshikusIII is offline
Vehicle: 2012 Dodge Ram 1500
Color: Dark Cherry Red
JoshikusIII is on a distinguished road
Correction: If you are a lazy, over-charging *******, then it is definitely necessary that you remove the brake booster to change the rear spark plugs. Better yet! Just pull the whole freaking motor out! IT'LL ONLY TAKE 10 MINUTES THEN!!! HA!
Old 08-29-2012, 01:49 AM
Rep:2657
cut holes in your inner fender wells
direct access
i have done it before
trick is to make shields to cover the holes
