Old 09-25-2012, 12:10 AM
ray5.9rt ray5.9rt is offline
Vehicle: 2005 dodge ram 1500 4x4
Color: LT BLUE
ray5.9rt is on a distinguished road
Did my plugs on my 05 last week end it was not to bad..3 1/2 hours and some advil for my broken back...lol. I went with the oem plugs also
Old 09-25-2012, 07:58 PM
bighemi04's Avatar
Rep:623
a magnetic spark plug socket WILL be your best friend
Old 09-25-2012, 10:58 PM
redlightmike redlightmike is offline
Vehicle: 2012 Ram Express RCSB
Rep:36
redlightmike is on a distinguished road
I changed the plugs in my 08 and i took about 3 hours.. its kind of a pain in the rear but it can be done, and without removing the booster.. i think the secred may be to hold you head at a 14.2 degree angle and break your forearm in 3 places.. then maybe you wont need the swivel lol.. seriously though, if you have few different size extensons and a few hours its not that bad
2012 Express RCSB..2/4 belltech drop, 22s,tonneau cover, 4.10s, true duals with x and magnaflows,vararam air grabber,180 tstat, 2800 circle d, diablosport trinity....headers and ported tb(coming soon)
Old 09-27-2012, 07:29 PM
cwbrow2's Avatar
cwbrow2 cwbrow2 is offline
Vehicle: 2010 Ram 1500 4x4
Trim Level: SLT Crew Big Horn
Color: Mineral Gray
Rep:18
cwbrow2 is on a distinguished road
Rookie DIY mechanic. I googled how to change plugs. Passenger side...easy day, unclip ac condenser hoses. Drivers side...pain in the a$$. But no big deal.
Parts needed:
Thick comforter...for laying across engine.
K-D tools magnetic spark plug kit off Amazon.
OEM plugs from Sparkplugs.com
Extensions..flex type.
Anti-seize
Patience
Beer
Patience
Beer
Patient wife
Beer
etc etc
Last edited by cwbrow2; 09-27-2012 at 07:31 PM. Reason: sorry..forgot gap tool...k-d tool also off amazon
Old 09-27-2012, 08:56 PM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
I just did my 2004 hemi. I think the older third gen hemi and the newer third gen hemi may be very slightly different but I'm not sure. Are the plugs oriented side by side, two to each cylinder? That's how mine are. Yes, it can certainly be done without removing the booster. I did it with no real special tools. Rather than cutting holes in the inner fender liner you could just remove it if you think it will help. I was told to remove mine and did (it's easy) but actually ended up getting to all of them from the top. It will take a few hours, some sore ribs from laying on the radiator support, some skinned knuckles, and a curse word or two but it's really not difficult.
As for the plugs, I would buy OEM or NGK and nothing else. These trucks are pretty picky about the plugs and they like OEM. You should be able to get OEM at your local parts place. Also, just a thought for you....I know lot's of folks just hand tighten and that may be just fine but be aware that Dodge says these engines have a "torque critical spark plug design" and that the plugs cannot be overtorqued. This is good advice for any aluminum headed engine anyway. Dodge says torque to 14 ft-lbs and no more than 15. I used anti-seize and torqued to 13.5. A small torque wrench that does inch-pounds works best and will be most accurate if you can get your hands on one.
