Old 08-27-2012, 01:47 AM
cabindoor00 cabindoor00 is offline
Vehicle: 2011 Ram 1500 Crew Laramie
Color: Pearl Brown
cabindoor00 is on a distinguished road
Default Turning off puddle lamps
I go hunting frequently and really don't like the puddle lamps on the exterior mirrors lighting up the whole area when I get into and out of the truck. Anyone know how to turn this off?
Old 08-27-2012, 02:20 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
try the dimmer switch roller. I turn that off when I get home with the kids and they fall asleep in the truck. I durn the dimmer switch all the way left I believe and the lights inside the truck stay off. Might work for the puddle lights too.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 08-27-2012, 08:51 AM
Rec 26's Avatar
Rec 26 Rec 26 is offline
Location: El Paso, TX via Centereach, NY, Vieques, PR, and San Antonio, TX
Vehicle: 2014 RAM 3500 Crew Cab Dually
Trim Level: Tradesman
Color: Bright White Clear Coat
Rep:71
Rec 26 will become famous soon enough
Send a message via AIM to Rec 26 Send a message via MSN to Rec 26 Send a message via Yahoo to Rec 26
Those lights still come on even with the interior lights dimmed down/turned off. When I replaced my right side mirror I noticed that there is a connector that runs from the side mirror to a power box (best way I can describe it) behind the door panel (which is real easy to take off) Only issue is that mine are also heated. Don't know if yours is as well or not. You can just leave that cable disconnected but I think it also gives power to adjust your mirrors or you can try to pry the lights open in and remove the bulbs. That or tint/paint those light or duck tape them when you go hunting and remove the duck tape with you are done
2011 Ram 1500 Big Horn Quad Cab "SRT Hauler Mark I" (traded in)
2014 RAM 3500 Tradesman Crew Cab "SRT Hauler Mark III"
Old 08-27-2012, 08:52 AM
Rec 26's Avatar
Rep:71
or.... (and I just thought of this)
plasti-dip the side view mirrors and make sure you get the lights as well.
Old 08-27-2012, 11:40 PM
LeftCoast's Avatar
Vehicle: 2012 Ram
Rep:248
Painters tape would leave less residue than Duct tape.
, BT Catch Can.
Old 08-28-2012, 01:26 AM
Color: Pearl Brown
Nice, I didn't even think of those ideas! Thanks!
Old 08-28-2012, 01:29 AM
Rec 26's Avatar
Rep:71
Thumbs up
LOL... Keep forgetting about painter's tape. Good call on that one.
