Codes P1762 & P1763, what parts? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 08-27-2012, 06:03 PM
05ram4x4's Avatar
05ram4x4 05ram4x4 is offline
Vehicle: 2005 Ram 1500 Quad Cab 4X4
Trim Level: SLT Sport
05ram4x4 is on a distinguished road
Default Codes P1762 & P1763, what parts?
I know I need a governor solenoid, and a pressure sensor, but I can't find the sensor anywhere? As in anybody who sells them? Based off of what I've looked up, those are what I need. It could also be the wires I read. My tranny doesn't shift out of first. And those are the codes that show up.
Any help at all? Anything i'm missing?
Thanks!
Old 08-27-2012, 06:34 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:141
Thanks!
www.makcotransmissionparts.com
I think you are looking for something like this:
# 12420BK Solenoid set, A500 / A518 / A618 OD & TCC, with gov. Pressure transducer, 1996-99
Includes #12420B = 8 Pin ROUND connector and #12415B = 4 prong gov. pressure sensor which uses the integral TOT sensor. 1996-2000 some. Kit will update 1994-95 models.
Which runs about 132.99
Here just click here http://www.makcotransmissionparts.com/A518.html and scroll down to solenoids and read each discription, make sure you select one that covers your year it's very impoartant. Your best bet is to remove the pan and look at whats installed now so you are 100% sure you order the correct part.
Old 08-27-2012, 07:55 PM
05ram4x4's Avatar
Thanks! I really didn't want to do anything until i had the parts in hand, but I guess I'll have to.
Old 08-28-2012, 07:36 PM
05ram4x4's Avatar
I am planning on ordering these two parts. Good idea? I could also order what you posted above (the whole kit) but i'm a little afraid to take the valve body out to get the the harness like people say needs to happen. If anybody has pics of it, and can explain the process better, that would be great! I removed these two pieces today along with the block they were attached to.
http://www.makcotransmissionparts.co...ct_Code=12432A
http://www.makcotransmissionparts.co...ct_Code=12415B
