Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 08-27-2012, 09:21 PM
Big Guy Big Guy is offline
Vehicle: 1999 Dodge Ram 1500 2WD
Trim Level: Laramie SLT
Big Guy is on a distinguished road
Default Water sloshing inside interior A/C and heater unit
Water appears to be sloshing inside vehicle A/C and heater unit forward of front passenger seat. It appears to be worse after vehicle has been sitting a few hours or overnight and goes away after vehicle is driven for a short while. I have checked the outside drain in firewall, which I have installed a 90 degree elbow (exit down of course), and condensate is dripping out. There is no leak inside the cab and carpet is dry. A/C and heater operate normally. Would it appear that this is normal? A/C often 'hisses' after vehicle is shut off as if pressure was equalizing inside unit. you thoughts or experience would be appreciated. Thanks, Jim
Old 08-27-2012, 09:23 PM
Ramtime7's Avatar
Ramtime7 Ramtime7 is offline
Vehicle: 2009 dodge ram 1500 slt
Ramtime7 is on a distinguished road
sounds like you have air in one of the lines, go get the fluid changed at the dealership
Old 08-27-2012, 10:50 PM
Sometimes it's better to remain silent and appear a ...
Old 08-28-2012, 02:16 AM
Rep:2640
get your system, heating & cooling burped
you have air in the system
Old 08-28-2012, 11:30 AM
Thanks, I will GOOGLE that one.
Old 08-28-2012, 11:36 AM
Default Thank you,
I wasn't sure if you were pulling my leg so I looked it up...thanks for the tip, I now know what the problem is and how to fix it. I really appreciate your reply. Jim
Old 08-28-2012, 12:38 PM
Default Thanks to first responder...
I don't know why that wasn't obvious to me...it seemed so simple after I read your answer that I thought I should not have even presented the question.
Thanks for your response...I think I will try to get the air out myself by the second responders' solution and if that doesn't work I will take it to the Dealer as you suggested. Thanks, Jim
Old 08-29-2012, 12:00 AM
Default Now I have a new problem...
When I started the process of getting the air out of the system tonight I could see that the water level in the radiator was low. That alone may be the reason for the air in the system. Tomorrow I plan to fill the radiator back up with anti-freeze and see what happens. If the sloshing is gone I'm all set...if not I will try the 'burp' procedure both responders in effect suggested. jOf course all of this brings to mind the reason for the low water level in the first place... BTY temp guage indicates normal range. Thanks. Jim
