Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Towing
Old 11-03-2012, 12:37 PM
sandawilliams's Avatar
sandawilliams sandawilliams is offline
Vehicle: 2014 2500
Rep:14
sandawilliams is on a distinguished road
Default Tow/haul
Heat is what kills automatic transmissions. I have towed at the max with mine for about 25000 miles now and always use tow/haul. I also use it when running empty under 65 MPH because with 3.55's that is where it shifts into OD. When the trans is hunting between gears it builds up heat that will shorten its life. Also when tow/haul it will downshift as your speed drops and brakes are applied to assist in slowing the load.
Old 11-08-2012, 03:45 PM
Bikenut's Avatar
Bikenut Bikenut is offline
Rep:73
When in TH mode, the tranny does not go into 6th gear.
Although I agree that hunting creates heat and heat kills transmissions, it is also good to drop a gear to flow fluid through the tranny and cooler to dissipate heat. Sitting in 5th may seem ok and with a lighter load may be alright, but part of TH logic is to keep the tranny from lugging and keep the heat transferring out.
Old 11-08-2012, 05:09 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
I almost always use T/H even when not towing. The only time I don't is if cruising at 75mph+. Even with 6th gear locked out in T/H mode I get the same mpg cruising at 70mph as if I were in 6th. I have so much more power without downshifting too. I have 3.55's. When I go to 4.10's I will use 6th gear on the highway, but still use T/H in city. It extends shift points a lot and that is great.
Sean
Old 11-08-2012, 11:44 PM
fastNugly @ RP's Avatar
Revel Performance
Rep:1804
Did not know this. Ill try this out tomorrow
sales@revelperformance.com
Old 11-09-2012, 08:41 PM
bpetroni bpetroni is offline
Vehicle: 2012 Ram 1500 5.7L
Trim Level: Crew Cab
bpetroni is on a distinguished road
I was told be the dealer if you are in T/H Mode and on a big hill and your tranny starts constantly hunting for gears to take it out of T/H and manualy shift to the best gear. This happened to me in my Silverado and I thought that the tranny was going to explode. Truck was rated for the weight but underpowered, that was before I got my Hemi....
Old 11-09-2012, 09:40 PM
TNC TNC is offline
Rep:12
TNC is on a distinguished road
If I recall I think the Trans Engineer guy addressed something about this. I think the scenario you're describing was common for some GM models, and maybe others, where in certain gear select positions you didn't get full tranny fluid circulation even if the tranny wasn't hunting and pecking for a solid gear. I think TE said this Ram tranny doesn't have that system. I had one of those GM vehicles with that tranny style for about 18 years before getting this Ram. You had to pay attention to your tach and gear position to insure a cooler running fluid when towing. TE said this Ram tranny maintains a full circulation through the cooler and torque converter, and that a too frequent shifting operation is what creates the excess heat.
But hey, I'm not trans engineer. I'll also speculate on the 5th gear and T/H mode. I think T/H is actually 5th gear on the manual selector, and that it makes the shifting and shift points more aggressive...maybe for less slippage and therefore less heat? But I really do think the gear you're in when in T/H mode is actually just 5th. Maybe TE will chime in on this.
Old 11-09-2012, 11:04 PM
snrusnak's Avatar
Rep:1388
The transmission oil pump is driven by the input shaft, so if the input shaft is spinning(if the engine is running) the transmission fluid is circulating. So it doesn't matter what rpm you are at, you will have sufficient transmission fluid flow which provides cooling.
The only things that change when in tow/haul mode is that the 6th gear is locked out, the third gear(2nd prime) enters into the normal shift pattern, and shift schedules are changed(higher upshift rpms and more engine braking). Shift quality, line pressure, shift time, etc are not changed.
Sean
Old 11-10-2012, 02:25 AM
Bikenut's Avatar
Rep:73
Ahh, good to know! I like what you're saying. And yes, gear hunting creates a lot of the heat problems.
Im going to test running T/H around town. Im sure it cant hurt and will make the truck feel better. And I doubt it will make the fuel economy much worse than it already is around town lol
Old 11-10-2012, 09:06 AM
snrusnak's Avatar
Rep:1388
Yeah it won't hurt, I even had a discussion with transengineer and he confirmed this.
I almost always lock out 6th gear, even when not in T/H because as long as I'm not going over ~70mph my mpg stays the same, and I have so much more power without giving it a lot of pedal to downshift. I usually only use 6th over 70mph, like on looooong trips. And I normally will use T/H when in traffic as it'll hold the gears longer, but if I get on county roads or something I normally shut it off.
Sean
Old 11-10-2012, 01:22 PM
Revel Performance
Rep:1804
i keep forgetting to try this.....
