Old 08-28-2012, 03:18 AM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Default [PHOTOS] Ported throttle body install, custom intake
Met up with a guy that runs a dodge performance business in Houston, TX and got a ported throttle body. I can feel the difference in the throttle response and pick up. I would recommend a ported throttle body over OEM. 12-24 HP bolt on
I also wanted to share some tricks about the rams intake system, and the proper way to get it set up.
Heres some side by side photos of the TB, new one on the left
Ported
Non Ported
Here is my setup
I used a piece of rubber bike tire around my air intake temp sensor, I have battled an air leak here for quite some time, but now have 100% of my air intake coming through the filter.
The other part of what I did was cut off the crankcase from the cold air intake.
And on the cold air intake port for the crank case I used another piece of tire to seal it off
I run a Huge Spectre cone filter
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 08-28-2012, 07:21 AM
bronx79's Avatar
bronx79 bronx79 is offline
Vehicle: 2005 dodge ram 1500
Color: dark blue
bronx79 is on a distinguished road
did you feel or notice better throttle response with your new TB?
Old 08-28-2012, 12:41 PM
sullivan's Avatar
Rep:202
Yes, much better throttle control and response.
Old 08-28-2012, 02:11 PM
moparornocar72's Avatar
Rep:630
I think ur ported and non ported pictures are backwards, the non ported one has the small slit at the top. It will definitely improve throttle response but I think no more than 12 HP and that's working in conjunction with your C.A.I. Thanks for the pics though!
14.268 @ 95 MPH Full Trim
Old 08-28-2012, 03:19 PM
sullivan's Avatar
Rep:202
Nope, I checked them and I have everything labeled correctly. The ported one is the one with the slit at the top
Old 08-28-2012, 06:50 PM
MF2000's Avatar
MF2000 MF2000 is offline
Vehicle: 2009 Ram Crew Cab
Color: Inferno Red
Rep:13
MF2000 is on a distinguished road
So who is the guy you bought the TB from?
Website, number?
How are you so certain of the hp increase? Dyno proven?
I'm not doubting you, just curious how you got the specific numbers.
Old 08-28-2012, 10:57 PM
Rep:630
Ok, the reason I thought that is because here is what mine looked like
Old 08-29-2012, 11:13 AM
BlackHemI's Avatar
Vehicle: 2008 Ram Hemi
Trim Level: Lonestar
Rep:296
yea im in Houston aswell so where is this guy and how much for the ported TB? would love to come out and meet you if your not far!
-Pat-
Old 08-29-2012, 03:19 PM
sullivan's Avatar
Rep:202
The guy I met, lives in conroe, works in downtown houston. I met him around minute maid park.
I will get in contact with him and see if I can get his number for you guys.
http://moesperformance.com/ is the website
ported throttle body is $300
Old 08-29-2012, 03:57 PM
BlackHemI's Avatar
Rep:296
oh yea hes on here i think his name is hemi450hp has a blue single cab as his picture
-Pat-
