Old 08-29-2012, 12:08 AM
FF54 FF54 is offline
Vehicle: 1998 Dodge Ram
Color: Ford Woodland Green with black added
Rep:26
FF54 is on a distinguished road
Default Bent Tie Rods
Hey guys and gals. Havent posted much lately, but been out doing a lot of wheeling here locally. Tonight though I failed to come out unscaved. Bent Tie rod and drag link after coming out of a new mud hole was trying out. I was wondering if the 3/4 or 1 ton trucks had heavier duty tie rods and drag links and would bot up pretty simply, or If I was going to have to build a set out of tubing and heim joints if I wanted stronger ones. I have a 1998 Dodge Ram Sport.
Oh and another casulty of tonight is possibly the throw out bearing. Not positive on that one yet though. Gonna see if I can get something like brake cleaner or what not sprayed up in there and clean it out.
Old 08-29-2012, 01:25 AM
dezertrunner dezertrunner is offline
Vehicle: 2001 Ram
Trim Level: Base
Color: Blue
dezertrunner is on a distinguished road
Replace with heim joints and Chromo tubing. Do the entire steering setup this way up to the pitman arm.
Anything else is really just a bandaid.
Old 08-29-2012, 10:42 PM
Rep:26
Good idea. kinda figured that was the answer I was going to get. The only problem is with the way the knuckles on the front axles are on these trucks, without changing them, you cant covert them to a cross over steering setup. So how are you supposed to connect the tie rod to the drag link?
Old 08-30-2012, 12:44 AM
battlerattle's Avatar
Vehicle: 2011 Power Wagon
Rep:256
With a 98, you should be able to pull the D60s off a wrecking yard 2500 and bolt them right up. Why not fix it all in one fell swoop!
Spyntec Hubs, 35" Cooper STT, Synergy Steering Brace, out of money........................
Old 08-30-2012, 06:40 AM
Rep:26
Because if Im swapping axles, Im going with axles from a Ford that have the high pinion and manual hubs, with no central axle disconnect.
