Old 08-29-2012, 10:56 AM
kenstauss kenstauss is offline
Vehicle: 2005 Dodge Ram 1500
Color: Gold
kenstauss is on a distinguished road
Default rpm cycles in park
My problem seems to be when i put the truck in park.
It's got a poweraid cold air breather and throttle body spacer(came with the truck)
I've replaced the map sensor and tested the tps sensor (voltages) and iac valve (mechanically it's fine).
the rpm's will typically go from around 700 to 1200 then back to 700 and it will do that for about 10x's unless i give it gas then it goes back to around 700-800 rpm's.
i had one instance where it was cycling when i left the truck running and came back and it had shut off.
It doesn't do it all the time and replacing the map sensor seemed to help but it's done it 2x since (replaced map sensor saturday).
Any help is greatly appreciated.
2005 Ram 1500 Quad Cab 4.7L Magnum
makes me feel like a kid again!!!
Old 08-31-2012, 12:32 AM
goatman65's Avatar
goatman65 goatman65 is offline
Vehicle: 2009 Ram 4X4
goatman65 is on a distinguished road
Default test the tps.. then replace it
I noticed a surging while in overdrive moving down the road... was 300-400 rpm range. tesit tested good.. still had the issue.. tested the tps using an ohm meter.. looked for a SMOOTH change as the sensor was moved through the working range... cleaned and put back on.. issue remained..
Replaced the TPS and the issue went away....
Goatman
idle, rpm
