Old 08-29-2012, 02:27 PM
06ram4.7 06ram4.7 is offline
Vehicle: 2006 Ram 1500
06ram4.7 is on a distinguished road
Default Combining Lifts?
I'm wondering if it is ok for me to lift my truck by using a few methods together. I have 1.5 coil spacers up front to start off. I'm putting in a 3" lift spindle which doesn't change ball joint angles at all, then 3" blocks in the rear. After that I want a 1 or 2" body lift. Would that be unsafe?
And since I'm just lifting the body 1" could I just get new bolts and poly blocks for all the mounts or would I need a full on lift kit? I doubt all that stuff you see in a 3" kit would apply to a 1" such as steering extensions, gas filler extensions, bumper brackets.
Any advice is much appreciated.
Old 08-31-2012, 02:41 PM
teddyrev teddyrev is offline
Vehicle: 2004 dodge ram
Color: silver
teddyrev is on a distinguished road
No just keep in mind that lifting a truck period lowers center of gravity but thats what lift i had on my old chevy.
Old 08-31-2012, 09:10 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Vehicle: 2014 Ram 1500
Rep:20
gopackgo69 is on a distinguished road
It raises the center of gravity. Anyway you'll be fine with all that. I have a 3 " spacer, 3" lift spindle 1.25 body lift and 3.5" lift in the back
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 09-01-2012, 01:06 PM
When you did your 1.25 body lift did you have any complications like steering extensions and fan shroud clearance?
Old 09-03-2012, 11:13 AM
gopackgo69's Avatar
Rep:20
Nothing with the steering, but I did remove the lower fan shroud piece, which comes off easily.
Old 01-04-2013, 01:58 PM
DodgeOnly23's Avatar
DodgeOnly23 DodgeOnly23 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Lonestar SLT Hemi
DodgeOnly23 is on a distinguished road
gopackgo69- What kind of spindles are u using? and could u post some pics! Id love to see more of the truck! its what i plan on doing.
